NGD: 1985 RR250 Project - Jemsite
post #1 of 17 (permalink) Old 05-27-2015, 11:56 AM Thread Starter
Got this one $270 shipped. I do have some questions though, and I did some research on the guitar itself and history. First I don't see a RR250 advertised/listed in the 1985 Catalog, If I'm reading the serial number on the back plate right it is a 1985 model, Second I don't see a RR250 w/an Edge trem, and from looking at the pics I can't tell if it's been modified to fit one. Doesn't look like it to me?!?
As far as the history goes I looked up the name Luigi Cilento (written in the pup cavity) and saw he belonged/belongs to a local New York band called Life in Ruins. If you look at the hardshell case there logo is plastered all over the side, and there is a MySpace sticker by the handle. I went and checked out his and the bands page, and I saw this same guitar in a couple pics which leads me to believe it was his. Now all of this is speculation, but hardly a coincidence.
Honestly I care more about the origins of the guitar itself....did it come from the factory w/the Edge trem? can't wait to get it in the mail and pull the neck off and do some more digging. I'll post some pics when I get it. In the meantime all I have is the link!
Scott 74 is offline
post #2 of 17 (permalink) Old 05-27-2015, 03:55 PM Thread Starter
Re: NGD: 1985 RR250 Project
I confirmed it is a RR250 with the neck stamps. Guitar has been modded to fit an Edge trem though not very well. Besides the hideous paint job to the outside of the case it s very clean on the inside! Debating if I want to leave it modded or return to original?!? Either way it will be a fun project.
Scott 74 is offline
post #3 of 17 (permalink) Old 05-27-2015, 03:56 PM Thread Starter
Does anyone know what the "A" on the neck stamps represents?
Scott 74 is offline
post #4 of 17 (permalink) Old 05-27-2015, 09:40 PM
I don't know about the A... Sure is a cool project though! Looks like the trem covers all the chisel work... though I guess if you were going to paint the guitar and fix it up you could sand/paint the inside of the trem cavity black. Would be a good player as is too... Kind of cool that you know the history!
FireEagle is offline
post #5 of 17 (permalink) Old 05-28-2015, 04:23 AM
Cool, man. Don't see many of those around. The '85 serial neckplates are fairly common for 1986 spec model instruments, usually K-L (Nov-Dec) ones - early production for 1986 release. That's why it's not in the 1985 catalogue .
I'd keep the Edge, but clean things up a bit.
Ashurbanipal is offline
post #6 of 17 (permalink) Old 05-28-2015, 11:31 AM Thread Starter
That's what I was thinking too. Since it's not in the 85 Catalogue it must be early production for 86. The neckplate serial number starts "F85" which would put production in June of that same year.
Yeah I'm thinking I am going to keep the Edge, but have the route cleaned up, and fixed. Thinking of putting new stud anchors in since these ones are old and I'm not even sure they're Ibanez. I have an extra set of the super trem studs that are definitely going to replace the non-locking ones. Now what to do with the back of the neck?!?
Scott 74 is offline
post #7 of 17 (permalink) Old 05-28-2015, 02:07 PM
An F plate...wonder if it's from another guitar.
Could leave neck stripped and oil it, like the 400 series RGs of that period.
post #8 of 17 (permalink) Old 05-29-2015, 01:19 AM
Nice axe man!
The edge tremolo is way better than the original tremolo, I would def. leave it in. A paf pro in the neck and super distortion in the bridge and your good to go!
B.B.A. is offline
post #9 of 17 (permalink) Old 05-29-2015, 11:40 AM
Cool find man! really looking forward to see when you put this Randy Rhoads... err i mean Rocket Road all together.
Rafafas is offline
post #10 of 17 (permalink) Old 05-29-2015, 05:58 PM Thread Starter
You know what the RR and Randy Rhoads connection never hit me until you said that *lol*! Well we talked about it last night, and decided the rest of the paint on the back of the neck is coming off. Going to leave what's left on the front only. Keeping the edge, but might have the stud anchors pulled out and new ones put in w/the Ibanez super studs. The studs that are in there are a lot longer than the Ibanez ones. After that going to have the headstock and body cleaned and buffed to clean it up and then gold w/black border RR pin striping to match the logo on the headstock. Have absolutely no idea for pups yet, but this one isn't a rush job. Just something for fun.
Scott 74 is offline
post #11 of 17 (permalink) Old 05-30-2015, 06:40 AM
The first Edge trems had long studs because the bridge was top mounted, so you might have to plug the holes and re-drill.
post #12 of 17 (permalink) Old 05-30-2015, 09:44 AM Thread Starter
Did not know that. So the anchors and studs may be Ibanez after all!
Scott 74 is offline
post #13 of 17 (permalink) Old 05-30-2015, 11:23 AM
RGTFanatic's Avatar
Cool project scott. this should be fun for 'ya.
The anchor on the right (treble) looks like it might be Ibanez, but not the other one. Obviously, whoever did this work originally used two different studs and anchors. One is course thread and the other is fine thread.
RGTFanatic is offline
post #14 of 17 (permalink) Old 06-01-2015, 04:55 AM
^^ Yes, I noticed this as well. Though, the right one appears to have been put in upside down because the top visible portion on the guitar has no fluting. So I reckon they're both Ibanez studs, as the posts certainly are and both fit.
The modern inserts are shorter and have a solid bottom (except Edge Pro period, iirc) because Ibanez started recessing the trems in 1987 and using locking posts, so the little set screws lock against metal and don't dig into the wood. I think Ryc posted a pic in another thread ages ago showing a comparison between the two types.
Anyway, I'm keen to see how this one turns out .
post #15 of 17 (permalink) Old 06-01-2015, 10:38 AM Thread Starter
Thx for the info guys. We talked about taking the case to have it re-covered since cleaning all of that gunk and permanent marker will be a nightmare! We're amazed how clean it is on the inside. Definitely going to have the anchors pulled and modern version w/super studs installed. We're not going to recess it to make it float just down only which I'm good with. My question is that going to be a problem with the shorter anchors/studs (talking setting the action)?
Scott 74 is offline
2 X 1985 DT Destroyers for Sale Kwazar Classified Ads: Guitars and Gear 2 11-01-2012 11:44 AM
FS: 1985 Ibanez Roadstar II Project/Parts guitar TX-Joe Classified Ads: Guitars and Gear 2 04-06-2012 08:52 AM
1985 pro line series dewar Pickups & wiring 23 03-03-2011 06:52 PM
FT/FS 1985 Fender Jazzmaster estaban22 Classified Ads: Guitars and Gear 0 02-28-2010 12:32 PM
1985 Roadstar Value? cornstar70 All Other Guitars (including Prestige) 1 01-21-2010 03:45 PM
