NGD: A confusing RG with JEM body - Jemsite
post #1 of 18 (permalink) Old 07-28-2015, 10:52 PM Thread Starter
I picked this up today from Kijiji; claims its an RG 550. Plays great and god knows what pups these are. Any help is appreciated to give this guy an identity. Also, the bridge cant be pulled back cos of the weird setup its in. Is there something I can do myself for this to go both ways? Advices welcome.
I paid 350 CAD for this so really didnt mind the issues. This is really the best neck Ive played, second to my Charvel So-Cal.
Man0warrioR is offline
post #2 of 18 (permalink) Old 07-28-2015, 11:06 PM
RGTFanatic's Avatar
Re: NGD: A confusing RG with JEM body
We need a pic of the back of the guitar and one of the input jack to know for sure. The setup is screwed up on it, that's why you can't pull up. the trem is already angled in the "pull up" position.
RGTFanatic is offline
post #3 of 18 (permalink) Old 07-28-2015, 11:10 PM Thread Starter
Here you go :
post #4 of 18 (permalink) Old 07-29-2015, 01:26 AM
RGTFanatic's Avatar
Cool....
It's an aftermarket body with a '94 neck. If it was done well, you got a good deal.
post #5 of 18 (permalink) Old 07-29-2015, 08:08 AM
Pickups look like old Ibanez Powersounds.
Mark_McQ is offline
post #6 of 18 (permalink) Old 07-29-2015, 07:55 PM
Hi!
If it's an aftermarket body, then it is extremely well made (excellent covers fit and other details) but it may be a refinished lower range JEM body also...
In case the pickups are weak, then replace them and you have a great RG/JEM guitar!
Cheers, JPB
IBZeP is offline
post #7 of 18 (permalink) Old 07-31-2015, 11:41 AM Thread Starter
I have no idea about powersounds. The neck pickups sound way too bright than usual. I'll get this checked soon.
@IBzeP: I have a Super Distortion pup id be installing on the bridge.
@RGTFanatic: So, its not done well. I have to get some routing done in the cavity since the trem bar doesn't go both ways. It hits the wood when pulled back; here's a pic:
http://i16.photobucket.com/albums/b1...psaqfm6gvj.jpg
I just fell in love with the neck. Now I really know what a "fast neck" is
post #8 of 18 (permalink) Old 08-01-2015, 11:04 AM
The bridge isn't set up properly.
It shouldn't be 'flush' with the body like that, when viewed from the side of the bridge. The side should look like it's angled up. Check Rich site, www.ibanezrules.com for a great tutorial on how this should be set up.
I can see in the picture that the bridge is way too far angled back. Just loosen the springs a bit until the knife edges (if you look at the side, you'll see the little dark insert) are parallel with the body. That should give you some nice pull-up.
Whomever set that guitar up didn't seem to have a clue.
I seriously doubt you'll need to do any routing once it's set up properly.
Meechy is offline
post #9 of 18 (permalink) Old 08-01-2015, 11:11 AM Thread Starter
Thanks Meechy. On it right now. All my other FR guitars have more space there tho hence I thought cavity works needed. Here's an example of my Jackson:
http://i16.photobucket.com/albums/b1...psfcawj2sv.jpg
post #10 of 18 (permalink) Old 08-01-2015, 11:36 AM
Right, but your Jackson has a flat-plate FR, the Edge has an upward angle on the side, it shouldn't be set flat like I see in your pictures.
Like I said; look at the little knife edge insert you'll see near the E strings right on the side of the bridge. Hold the guitar in playing position and look down at it, into the cavity. You'll see what I mean.
Rich's site describes it better, and with pictures.
Have fun.
Meechy is offline
post #11 of 18 (permalink) Old 08-01-2015, 12:40 PM
RGTFanatic's Avatar
Like I said; look at the little knife edge insert you'll see nere the E strings right on the side of the bridge. Hold the guitar in playing position and look down at it, into the cavity. You'll see what I mean.
Have fun.
THIS^^^^
By getting the trem angle correct, you'll gain a fair amount of pull-up. This is definitely an aftermarket body (Perle?) with a horrendous setup. Once the setup is right, you'll be amazed at how much more you like it.
Here is the section on Rich's site that give you all the information you need for setting up your trem...... Go directly to the Edge/Lo-Pro section.
http://www.ibanezrules.com/tech/setup/angle.htm
post #12 of 18 (permalink) Old 08-01-2015, 12:43 PM
RGTFanatic's Avatar
If you have a lot of time (and a few beers) read through the whole tech section, writing down notes that apply to your guitars. This is the Ibanez players guide to getting the perfect setup for each player. Rich deserves an award for putting out this much info. It took him YEARS worth of experience and countless hours compiling all of it for us......
post #13 of 18 (permalink) Old 08-01-2015, 03:11 PM
THIS THIS THIS ^^^^^^^^^^^^^^^^^^^^^^^^^^
Ibanez should link to his setup site, it's that good!
And no; I'm not biased because of our mutual ladder fetish.
(Sorry, couldn't resist. LOL)
Meechy is offline
post #14 of 18 (permalink) Old 08-07-2015, 12:41 PM Thread Starter
I read through the ibanezrules setup material and damn it helped ! Thanks RGTFanatic.
Meechy, I now have it setup for pull-ups without any cavity work. Thanks a lot for saving me some time and money. My guitar guy said otherwise.
Since I have a loose arm, I tried to follow what a youtube video showed. i.e. to remove bushings and expand it. In the process I made it worse by losing one : [
I'm looking to buy an arm/bushings from ibanezrules. Thanks again for all the tips
post #15 of 18 (permalink) Old 08-07-2015, 12:46 PM Thread Starter
Btw, can you guys give me a lil' insight on how to make a floating trem flutter (a la Steve Vai's). Is there a sure fire way?
ibanez jem , original edge , project guitar , rg550 , steve vai
Ibanez is really confusing. dex_ibanez All Other Guitars (including Prestige) 12 12-15-2005 05:04 PM
RG models and names! confusing! Tribute All Other Guitars (including Prestige) 12 11-21-2005 09:01 PM
confusing RG550 Robot Boy All Other Guitars (including Prestige) 17 10-13-2005 07:56 PM
RG1527 colors . . . so confusing Exhale All Other Guitars (including Prestige) 14 07-27-2005 12:58 AM
Odd and Confusing Pull-back problem Vai the god of Sound Tech: Setup, Repairs and Mods 19 07-08-2002 01:47 PM
