Noob question about Ibanez model pecking order. - Jemsite
post #1 of 9 (permalink) Old 03-29-2007, 06:18 PM Thread Starter
Hi Guys,
I'm new to the forums and new to guitars in general. I haven't bought my first electric yet but I'm really drawn to Ibanez. So far I have the 2006 catalog, and I've looked at the 2007 online. But what I can't figure out is how the general pecking order goes with the various models. (and part of that is probably because the catalogs don't contain pricing).
Not sure if I missed an obvious FAQ somewhere, but could someone please walk me through the general history/basics of the various models? For example, how the RG series compares to the S and SA, etc.?
All I've been able to do so far is slowly "decode" which guitars appear to have better pickups, etc. than others. But I know there's gotta be more to it than that.
Thanks!!
Inzane is offline
post #2 of 9 (permalink) Old 03-29-2007, 07:45 PM
Re: Noob question about Ibanez model pecking order.
I'm by no means an expert, but you've probably noticed that the higher the number within a model, i.e. RG or SA, the "better" the guitar. As for what RG, SA, UV, etc, etc.
The catalog explains what body shape, neck design, wood, bridges, pickups, and so on the various model groups have.
The same page that you likely found the 2007 catalog has a separate price list PDF to download. A quick check of a few guitars available at a large, national "chain" store lists their selling price approx 25% below the "retail" price in the catalog.
hall is offline
post #3 of 9 (permalink) Old 03-29-2007, 08:14 PM Thread Starter
Thanks. Your pricelist tip was a big help. Not only does it have the pricing, it has all the specs listed together in nice columns so it makes direct comparisons easier.
Now all I have to do if find out how this pricing (assuming its US) compares to Canadian pricing. Similar to other types of products, companies' pricing doesn't always reflect currency exchange rates directly.
Inzane is offline
post #4 of 9 (permalink) Old 03-29-2007, 09:59 PM
Dee
Maybe this will help. It's an incomplete list and probably somewhat out of date, but anyway...
RG8xxx - Japan, J custom, Dimarzio pickups, hand crafted
RG3xxx - Japan, Prestige, Dimarzio-made IBZ pickups, maple top
RG2xxx - Japan, Prestige, Dimarzio-made IBZ pickups
RG1xxx - Japan, Prestige, V-series pickups
RG7xx - Japan, Wizard neck, later models had direct-mounted pickups, early ones did not
RG6xx - Japan -- similar to the RG7xx series, but only intended for Europe
RG5xx - Japan, Wizard neck, Edge Pro
RG4xx - Japan, Wizard II neck, Edge Pro (early RG470 had Wizard neck and Edge trem, then production moved to Korea and the spec suffered)
RG3xx - Indonesia (was Korea), wizard II neck, Egde III (was Edge Pro II)
RG2xx - Indonesia (was Korea), Wizard II neck, non-locking trem
RG1xx - Indonesia (was Korea), Wizard II neck, pickguard, non-locking trem
RGx7x - H-S-H pickup configuration, direct-mounted pickups, sharktooth inlay
RGx5x - H-S-H, pickguard
RGx2x - H-H, direct-mounted pickups
RGxx7 - 7-string
RGxx1 - hardtail
EXAMPLES:
RG2550 = RG2xxx + 5xx + x5x
RG2550 = Japan, Prestige, Dimarzio-made IBZ pickups, Prestige Wizard neck, H-S-H, pickguard
RG370 = Indonesia (was Korea), Wizard II neck, H-S-H, sharktooth inlay, Edge III
RG321 = Indonesia (was Korea) , Wizard II neck, H-H, hardtail
RG1527 = Japan, prestige, V-series pickups, Wizard neck, Edge Pro, H-H, direct-mounted pickups, 7-string
Dee is offline
post #5 of 9 (permalink) Old 03-29-2007, 11:56 PM Thread Starter
That's great. Thanks!
Now how does the RG lineup as a whole compare with the S and SA series?
I'm kinda scoping ahead for my future first electric guitar purchase and can see guitars in my potential price range in all 3 of those series. How will I know where I should focus?
Inzane is offline
post #6 of 9 (permalink) Old 03-30-2007, 12:03 AM
Dee
The S series has changed a lot over the last few years. They are all made outside of Japan now, as far as I know, and they are not as thin and sleek as they used to be. They used to have the Wizard neck (the thinnest) and now they have the thicker Wizard II, plus the pickups and strings are way higher off the body which changes the feel of the guitar quite a bit. Also they have the ZR trem. It's a good bridge, but very different feeling from the Edge / Edge Pro and Lo-Pro models. The newer S body is thicker, which kinda defeats the whole purpose of the guitar. I would say look for an older S model if you want one of those, they used to be amazing.
RG series is VERY different from the S series. I'm not sure about the SA, I know very little about them. RG is my "speciality", so to speak.
Dee is offline
post #7 of 9 (permalink) Old 03-30-2007, 12:09 AM
Not that the SA's are MY specialty, but I know they have a tapered top and a flat back, whereas the S series has tapered back AND sides. The SA strikes me as kind of a cross between an RG body shape and an S.
Hikey Mikey is offline
post #8 of 9 (permalink) Old 03-30-2007, 12:15 AM Thread Starter
If I can see myself aiming for a JS or JEM as a future goal someday, should I be bringing myself up on the RG foodchain then?
Inzane is offline
post #9 of 9 (permalink) Old 03-30-2007, 12:21 AM
Dee
It's up to you man. You can't really go wrong with a good Japanese-built RG, but as I said, there are some great older S models out there on the used market.
Dee is offline
body shape , dimarzio pickup , dimarzio pickups , edge trem , electric guitar , mounted pickups , prestige wizard , prestige wizard neck , sharktooth inlay
Another Question about Ibanez SA H3yl0 All Other Guitars (including Prestige) 0 11-29-2005 06:34 PM
FS: Ibanez Universe UV7BK '97 Model Year joe1 Classified Ads: Ibanez JEM/UV Guitars 2 09-28-2005 07:51 PM
Ibanez Paul Gilbert model specs, photos, and notes from Paul www.racerxband.com All Other Guitars (including Prestige) 14 05-03-2004 09:55 AM
'77 Ibanez Hollowbody - model number?? swirlmutha All Other Guitars (including Prestige) 1 04-06-2001 02:22 PM
