oil/grease for edge zero - Jemsite
post #1 of 9 (permalink) Old 07-27-2010, 01:55 AM Thread Starter
ebh
Hi
I used some product called red grease on my tremolo arm to make it loose (and I can fix it in position by tightening the nut on it).
The problem is that it started to wear down the finish on it, like it's attacking the black chrome or something. This happened in about a year...
In the manual it sais to use some kind of grease/oil on the tremolo, the question is what would be a good product that wouldn't attack the finish/metal?
Thanks!
ebh is offline
post #2 of 9 (permalink) Old 07-28-2010, 03:35 AM
Tank's Avatar
Reviews: 65
Re: oil/grease for edge zero
Chapstick. (no kidding)
Tank is offline
post #3 of 9 (permalink) Old 07-28-2010, 06:42 AM
I'd probably find some sort of graphite-based lubricant. On my trems, I use Suzuki Super Grease C. Seriously, that's what it's called. I have a little can of it sitting around because it's what Suzuki recommends to grease the steering head bearings on the bike. I put little dabs of it on the knife edges and on the trem posts. If I were less lazy, I'd go get some graphite lubricant.
Takin' a Ride is offline
post #4 of 9 (permalink) Old 07-28-2010, 12:12 PM
i use silicone grease
asolid is offline
post #5 of 9 (permalink) Old 08-17-2010, 02:43 AM Thread Starter
ebh
Can I use something similar? We don't have chapstick brand in my contry.
ebh is offline
post #6 of 9 (permalink) Old 07-27-2011, 03:55 AM
I use two type of greases called Molykote DX and Fomblin UT18 on the studs on all my floating trems. I have tried alot of different type of greases and chapstick but I found these much better for heavy steel to steel contact because it reduces the wear and it always stays where it should be for a longer time and it's more tolerant to different kind of fluids that your guitar can be exposed to.
mrtrapp is offline
post #7 of 9 (permalink) Old 07-27-2011, 07:20 AM
I use a product called "Big Bends Nut Sauce" on the studs and the arm. Works amazing and no issues with finish/metal.
PBGas is offline
post #8 of 9 (permalink) Old 07-27-2011, 08:32 AM
Reviews: 21
Is your finish powder cosmo? If so the lubricant probably has nothing to do with it. Powder cosmo is the biggest joke on the planet in terms of guitar hardware finish. It will wear off in a month from just the sweat and acid in your skin. If you're going with an inexpensive Ibanez (from Indonesia or China) always get black hardware if you're worried about aesthetics.
mike570 is offline
post #9 of 9 (permalink) Old 08-04-2011, 06:49 PM
Candle wax
GetSynyster is offline
edge zero , grease , oil , prestige
Similar Searches
LF: Lo-Pro Edge, Edge Pro or Edge Pro II in Madrid Spain kevlahnota Classified Ads: Guitars and Gear 2 03-24-2010 11:40 AM
WTB: Ibanez edge/LP edge/edge pro saddle mounting screws Ratit Classified Ads: Guitars and Gear 0 04-18-2009 08:16 PM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
Trem Grease null_is_one Ibanez JEM, UV, JS & Other Signature Models 12 06-10-2005 01:44 PM
Removing grease and dirt from fretboard with benzine? burt777 Tech: Setup, Repairs and Mods 11 07-09-2003 01:31 PM
