one more pickup question for RGA's... covered pickups fit the routing? - Jemsite
post #1 of 3 (permalink) Old 03-15-2007, 12:38 PM Thread Starter
I'm ordering a set of bare knuckle pickups for my rga, and I wanted to make sure that covered pickups will fit before ordering them. A friend installed emg's in his rga321f and he said he had to have his tech grind down the screw mounts in order for the emg's to fit the cavity correctly. Do you guys know if I will have this same problem with regular covered passive pickups? I could just get open poled, but since I was ordering bare knuckle, I figured I would get some interesting, unique looking covers....
JoshuaLogan is offline
post #2 of 3 (permalink) Old 03-15-2007, 02:38 PM
Reviews: 14
Re: one more pickup question for RGA's... covered pickups fit the routing?
Those pickups should definitely fit as I've seen an RGA121 with BareKnuckle PU sell on bay-E. So, unless that seller altered the guitar without mentioning it they must have fit right in.
With your friend's guitar do you mean he had to grind down where the pickups mount in the guitar? I know when I put my DiMarzio X2N into my RGA I had to do that because the pickup is fairly tall (the backing plate is the same size as the stock pickups, though) and when screwed down completely flatly to the guitar it was too high. A little dremel tooling later it was low enough. Wasn't hard to do.
Johnny Two Tone is offline
post #3 of 3 (permalink) Old 03-18-2007, 12:57 PM
I put a Gibson 57' Classic Plus covered p/u in the neck position of my RGA121 without any problems. It should be fine, you might have to do a little routing with some p/us, but its not that hard, as Johnny Two Tone stated.
clnh5 is offline
bare knuckle pickups , neck position
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 09:35 AM
Interesting pickup concept - single-string pickups on rails? darren wilson Gear, Equipment, Recording & Off Topic 8 03-16-2002 08:57 PM
Covered pickups in a JEM - Anybody done this? GuitarLunatic Ibanez JEM, UV, JS & Other Signature Models 8 03-08-2002 08:02 PM
Breeds vs Blaze pickups - UV 7 string pickup questions wireman24 Ibanez JEM, UV, JS & Other Signature Models 4 01-17-2002 10:03 PM
Pickup Selector - different pickups for different sounds kylemac Gear, Equipment, Recording & Off Topic 6 07-27-2001 04:00 PM
