Our first 7-string trem body - Jemsite
post #1 of 25 (permalink) Old 05-11-2005, 12:07 PM Thread Starter
I was planning to add a trem to the line up in the fall, starting with the 6-string, but a custom order came in for a 7-string trem so we dove into the deep end first. We've been working on this for a few months now and we've finally got the body cut. It's routed for a Hipshot trem.
Jim Soloway is offline
post #2 of 25 (permalink) Old 05-11-2005, 12:53 PM
Flobanez's Avatar
Re: Our first 7-string trem body
Nice. I like those woods.
Flobanez is offline
post #3 of 25 (permalink) Old 05-11-2005, 01:37 PM
As clean as always Jim, Top work
Rob
Jem7RB MK is offline
post #4 of 25 (permalink) Old 05-11-2005, 04:49 PM
Is the hipshot trem floating? Got a pic of it !
Regards
André
fettouhi is offline
post #5 of 25 (permalink) Old 05-11-2005, 06:25 PM Thread Starter
Regards
André
No. They sent me one for design purposes and we've sent that back. THe one we're actually using is gold plated and I won't have it for another two or three weeks.
post #6 of 25 (permalink) Old 05-11-2005, 06:46 PM
Nice craftmanship! Do you offer other body shapes? That shape just doesn't get it for me,,,, I think it's the lower horn that throws it off. Would like to see pics when it's all done.
~A
Allen Garrow is offline
post #7 of 25 (permalink) Old 05-11-2005, 06:52 PM
Flobanez's Avatar
Jim, Any other body shapes you're experimenting with?
Flobanez is offline
post #8 of 25 (permalink) Old 05-11-2005, 07:07 PM Thread Starter
Not really. We're probably going to do a solid body the same basic shape but with rounded edges and we've been doing several with no sound hole (still chambered though), but other than that, I'm focused on smaller refinements to the existing model. Right now that's taking pretty much all the energy we can muster.
From a purely practical standpoint, this body shape works incredibly well. It allows us to build them incredibly light weight (our newest guitars are just over 5 lbs for a 6-string and 6.3 for a 7-string) and still keep them well balanced. They hang really nicely even on a polished leather strap. In addition to helping with the balance, the shape of the lower cut away provides easy access to the upper frets and allows it to play well sitting as well as standing. It's different enough that I know everyone isn't going to love it, but as long as enough do, that's just fine.
post #9 of 25 (permalink) Old 05-11-2005, 07:10 PM
is that a one or a two peice body?
Globbits is offline
post #10 of 25 (permalink) Old 05-11-2005, 07:13 PM Thread Starter
2 piece. I don't think a one piece body could handle the stress of either a 7-string or a trem.
post #11 of 25 (permalink) Old 05-12-2005, 11:07 AM
jim777's Avatar
Beautiful top Jim, and I love the swamp ash (who doesn't?). Is the trem going to be piezo equipped? That would be cool!
jim777 is offline
post #12 of 25 (permalink) Old 05-12-2005, 11:14 AM Thread Starter
No. At this point is an either or situation. I haven't figured out how to have both and keep the bridge stable.
post #13 of 25 (permalink) Old 05-12-2005, 11:31 AM
That's awesome, Jim! Nice work.
I'm thinking with some thought you could get a piezo-trem to work. The Hipshot saddles look like they'd accomodate the Graphtech Ghost piezo saddles. What are the issues? Stability? How so? (Curious because Iv've thought alot about this same thing, but you're actually doing it.)
Again, very cool.
The Dark Wolf is offline
post #14 of 25 (permalink) Old 05-12-2005, 11:58 AM Thread Starter
Again, very cool.
The problem is not the saddles. The Graph Tech saddles and the Hipshot saddles are interchangable. The problem, as always is what to do with the wires.
All of our non-trem guitars are built to be piezo-ready. Our standard bridge is custom milled for us by Hipshot. One of the custom features is a hole that's hidden under the saddle for the wire from each piezo saddle to pass through. Under the top there is a channel routed into the body that lines up directly under those holes that runs out to the control cavity. With the trem, that system doesn't work. That cavity would be under the front of the bridge and with the body has to be routed all the way through, it would weaken the body right at the point where it needs to be the strongest.
So the question becames, how to get the leads from the trem ver to the control cavity? You can't come through the bottom of the bridge because the wood's all been routed away for the spring cavity. I suppose you could bring the wires forward and run them through a channel about 3/4 inch in front of the bridge, but that would look incredibly messy with a lot of exposed wires. You'd still have to route a channel to the control cavity which means it would create a stress point in the body that I think is still too close to the bridge.
I think the real answer is either a different type of trem or even better, a different type of piezo that's not part of the saddle.
post #15 of 25 (permalink) Old 05-12-2005, 02:01 PM
Why not have a single narrow channel that runs from the trem cavity into the bridge pickup cavity under the top? Then just bundle the wires together and run them through the pickup cavity into the control cavity.
darren wilson is offline
body shape , bridge pickup , darren wilson , edge bridge , guitar mag , pickup cavity , spring cavity , swamp ash , trem guitar , upper fret , upper frets , wilkinson trem
FS: Ibanez 7-string body and neck, DiMarzio 7-string pickups, ... bwherry Classified Ads: Guitars and Gear 13 08-12-2008 01:05 AM
Ibanez PGM 30 body, Lo TRS trem, will a Lo Pro work on this body? born2liftanitowoc Tech: Setup, Repairs and Mods 1 07-21-2007 10:25 AM
Can You Put A Zr Trem On A Rg Body???? jl2556 All Other Guitars (including Prestige) 2 05-25-2005 11:28 PM
width of a 6 string vs that of a 7 string ibanez body shredmaster26 Tech: Setup, Repairs and Mods 6 08-10-2003 12:11 PM
Suggestion on axe: string through body/neck through body? ericbrowning All Other Guitars (including Prestige) 4 01-23-2001 11:46 PM
