Paint on the neck heel and neck pocket? - Jemsite
post #1 of 10 (permalink) Old 05-25-2011, 04:05 PM Thread Starter
Reviews: 8
Hey all. Got a 1982 Rocket Roll II here, and when I took the neck off earlier today, I noticed that the neck pocket still had paint inside, and the heel was also painted. Now, I'm far from an expert, but I'd think that this would mean less efficient transfer of vibrations to the body from the neck, which would result in decreased sustain, so what should I do?
Think I should just buy some sandpaper and remove it? By "painted" I mean that it's got exactly the same amount on it as the rest of the neck; the pocket is less covered.
Thanks.
meticadpa is offline
post #2 of 10 (permalink) Old 05-25-2011, 04:37 PM
Reviews: 98
Re: Paint on the neck heel and neck pocket?
I'd lightly sand off the finish in the pocket and on the heel.
AlaskaBat is offline
post #3 of 10 (permalink) Old 05-25-2011, 04:39 PM Thread Starter
Reviews: 8
Thanks. I've got some 200 grit, 400 grit and 800 grit sandpaper here, so that's what I was considering doing! I'd use a sanding block, of course.
post #4 of 10 (permalink) Old 05-25-2011, 05:03 PM
Reviews: 11
Careful with the neck pockets. I like using flat files over sand paper for those, simply because its hard to sand properly in that confined space.
linuxpenguin is offline
post #5 of 10 (permalink) Old 05-25-2011, 05:05 PM Thread Starter
Reviews: 8
The neck pocket's paint layer is very thin; it'll probably just take a little bit of gentle rubbing (we're still talking about guitars here) to come off, even with some high grit sandpaper.
post #6 of 10 (permalink) Old 05-25-2011, 05:10 PM
Reviews: 11
LOL
Even with "gentle rubbing" Id still suggest a nice high grit flat file, or at the very least, get a tongue depresser stick and tape sandpaper to that to get a flat sanding surface
post #7 of 10 (permalink) Old 05-25-2011, 05:12 PM Thread Starter
Reviews: 8
Originally Posted by linuxpenguin View Post
LOL
Ahh, okay then; thanks for the advice! I wonder how much of a difference this will make. I'll probably have to lower the action on my guitar a bit too, since the neck will be sitting lower in the pocket.
post #8 of 10 (permalink) Old 05-26-2011, 02:22 PM
It will make a difference but you need to be careful not to remove too much material, as the neck needs to fit snug in the pocket. You may need to glue a couple shims in there afterward to get the neck to fit right.
musikron is offline
post #9 of 10 (permalink) Old 05-26-2011, 02:49 PM Thread Starter
Reviews: 8
Yeah, I'll be very careful. I don't want to risk screwing this up - the guitar is fairly rare these days!
The neck is actually a little too big for the pocket currently anyway, so it actually makes sense to remove this.
post #10 of 10 (permalink) Old 05-26-2011, 11:44 PM
It makes a lot of sense. The neck pocket should be unfinished, but in an effort to cut production costs a lot of mass produced guitars cut corners, and thats an area where they figure they can be lazy.
musikron is offline
flying v , ibanez , rocket roll
WTB: PGM100 neck r other square heel neck Chewy5150 Classified Ads: Guitars and Gear 4 05-12-2011 11:08 AM
Neck is moving in the neck pocket hollow125 Tech: Setup, Repairs and Mods 7 04-17-2008 05:30 PM
Misaligned neck in neck pocket (Rg570) superhairycamel Tech: Setup, Repairs and Mods 4 06-10-2007 09:01 PM
depth of neck pocket , height of the neck .. j.arledge Tech: Setup, Repairs and Mods 0 03-03-2007 09:17 PM
Very loose neck to neck pocket fit, what do I do? SilverSurfer2 Tech: Setup, Repairs and Mods 3 07-29-2005 09:00 PM
