Painting a guitar - Jemsite
post #1 of 10 (permalink) Old 07-11-2007, 03:33 AM Thread Starter
Painting a guitar
hello gentlemen.
Long story short, my gf's birthday is coming up and Ive planned to take an old guitar body, paint it her favourite colours and put her name on it (something she can hang in her room)
What sort of paint should I be doing this with? Is a decent brand of spraypaint (ironlak, belton, montana) going to get the job done (with an undercoat, primer)? Or should I be using a different type of paint?
wallie! is offline
post #2 of 10 (permalink) Old 07-11-2007, 05:21 AM
Re: Painting a guitar
It'll take a little more than just paint. First, sanding. Then, wood spirits and (multiple layers of) primer. Then, the actual paint. Then, clear-coating/finishing. It'll take more than a day, if that's what you're thinking. Considering if you don't have heat lamps, primer and paint dry overnight. And you'll need at least four layers of each (that's being conservative).
CityofBlindingLights is offline
post #3 of 10 (permalink) Old 07-11-2007, 06:25 AM Thread Starter
thankyou city, that all seems fairly manageable at this point, will it be fine using spraypaint?
I want a nice quality of work, so will spraypaint achieve that? or should I be using paint and a brush or something?
wallie! is offline
post #4 of 10 (permalink) Old 07-11-2007, 12:44 PM
Spray paint will get a you a nice paintjob if you know what youre doing. It takes alot of practice and precision to get even coats and a paintjob without any mistakes.
RG462 is offline
post #5 of 10 (permalink) Old 07-11-2007, 01:57 PM
No, spraypaint will get the job done. From what I've heard, standard Krylon spraypaint is not only the best spraypaint to use, but also one of the cheapest. The key in painting guitars would be to get even coats, probably holding the can about six inches away from the body. Also, you'll need to completely disassemble the guitar (including electronics and neck) to paint it, unless the guitar won't be played at all. Then you can just mask off whatever you don't want painted.
Once you start, the best way to learn is trial by error
post #6 of 10 (permalink) Old 07-11-2007, 04:26 PM
You might want to check these pages out...
http://www.projectguitar.com/tut/tutorial5.htm
Mikael Jurman is offline
post #7 of 10 (permalink) Old 07-11-2007, 05:30 PM
Spraying clear with cans is pretty tricky.
C.Thep is offline
post #8 of 10 (permalink) Old 07-11-2007, 09:18 PM
Yeah, projectguitar.com has a LOT of useful tips and info... snoop around and check it out, it's super helpful.
post #9 of 10 (permalink) Old 07-11-2007, 11:31 PM Thread Starter
thanks guys, much appreciated.
wallie! is offline
post #10 of 10 (permalink) Old 07-11-2007, 11:40 PM
Have a look on Stewmac.com - they sell various guitar refinishing products (including water borne lacquers) in foo foo cans - make your life easy!
Also, Guitar Reranch are quite good in terms of advice - they told me you can spray Nitrocellulose lacquer over acrylic colour - something very few poeple seem to admit to.
David McCarroll is offline
guitar body
My New Chrome Guitar (Yamaha Pacifica) cakewalkr7 All Other Guitars (including Prestige) 25 05-01-2009 07:16 PM
Painting The guitar Marco Dalla Fiore Ibanez JEM, UV, JS & Other Signature Models 33 02-02-2009 04:06 PM
GUitar transition dillema..PLEASE HELP!!! pera_a777 All Other Guitars (including Prestige) 10 08-08-2006 02:55 PM
Somebody stole my guitar!! Please help me find it PatrickSimsCustomShopUSA Vendors, Auction & Reseller Talk 27 08-01-2006 01:04 AM
painting a guitar marshall Tech: Setup, Repairs and Mods 1 11-21-2003 09:34 PM
