PGM100-neck replacement,which wizard? - Jemsite
post #1 of 2 (permalink) Old 07-12-2005, 06:22 PM Thread Starter
My question is, what kind of neck is originally on a Pgm100?........and the 2nd question is, which wizard necks from which rg or prestige models could i replace the original one with without modification?....THanx in advance.
sitamoia50 is offline
post #2 of 2 (permalink) Old 07-12-2005, 08:59 PM
Re: PGM100-neck replacement,which wizard?
I'm pretty sure the necks on those was the same as what was on the RG7XX series guitars. The only exception would be if the fret size ws different.
If you're just looking for which neck would bolt on, any of the old square heel neck joint 24 fret RG wizard necks will work. An RG7XX series would be closer just because of fingerboard and headstock binding and sharkstooth inlay. Is your original broken or something? --Jason
jkahrs is offline
fret size , headstock binding , heel neck , neck joint
WTB: PGM100 neck r other square heel neck Chewy5150 Classified Ads: Guitars and Gear 4 05-12-2011 11:08 AM
Whats the difference between a classic 1987 Wizard neck and a Wizard Prestige neck? Duck_man All Other Guitars (including Prestige) 10 08-19-2007 11:01 PM
Lighter replacement body for RG320DX Wizard II neck? finstah All Other Guitars (including Prestige) 2 07-04-2007 10:08 PM
Wizard II Neck Nut Replacement Question Dark Alone Tech: Setup, Repairs and Mods 10 09-13-2006 09:22 AM
PGM100-neck replacement,which wizard? sitamoia50 All Other Guitars (including Prestige) 0 07-12-2005 06:19 PM
