PGM301 1 piece neck vs PGM 301 J-Craft - Jemsite
post #1 of 7 (permalink) Old 07-19-2010, 05:32 AM Thread Starter
Anyone knows which model of pgm301 is the best? The one with one piece neck or the one with 5 part neck (J-craft Team).
kaskenfer is offline
post #2 of 7 (permalink) Old 07-19-2010, 09:01 PM
Re: PGM301 1 piece neck vs PGM 301 J-Craft
BUMP this in hopes of a reply because I'm interested in hearing opinions of 5 piece necks vs. older single pieces -- on any Ibanez, PGMs included.
RedTiger is offline
post #3 of 7 (permalink) Old 07-19-2010, 09:31 PM
Seriously there is no difference in playability or feel,it's just a construction technique.
Each is a s good as the other.
If you spear your guitar into walls then the true benefits of each would become apparent.
In which case the J team 5 piece would be a little tougher IMO
corey j grieve is offline
post #4 of 7 (permalink) Old 07-19-2010, 09:46 PM
elcid's Avatar
The way it was explained to me was the 5 piece neck resists warping better because the 5 pieces of wood will all react differently to humidity and temperature change where one piece necks only have one piece of wood to react to those changes.
elcid is offline
post #5 of 7 (permalink) Old 07-19-2010, 09:53 PM
This is true,it was explained on the Ibanez site when they first made the change.
post #6 of 7 (permalink) Old 07-20-2010, 10:58 AM Thread Starter
Thanks for your anwers, It seems that i can go for this J-craft PGM 301 without hesitation then...
post #7 of 7 (permalink) Old 09-19-2010, 06:22 PM
What kind of neck is on the PGM301 Wizard II ?
Armann is offline
What does "5 piece or 3 piece neck" mean? kleyver Tech: Setup, Repairs and Mods 6 05-25-2010 09:59 PM
3 or 5 piece neck? Fang Gear, Equipment, Recording & Off Topic 4 12-18-2008 05:13 AM
WTB: Older one piece JEM neck karmannjen Classified Ads: Ibanez JEM/UV Guitars 5 11-13-2008 06:49 PM
J-Craft case + Square neck Joint = Fit piranha Gear, Equipment, Recording & Off Topic 0 03-08-2008 02:34 AM
JEM7vh... 5 piece or 1 piece neck Barra R. Ibanez JEM, UV, JS & Other Signature Models 4 02-21-2006 09:03 PM
