Pickguard Advice? - Jemsite
post #1 of 7 (permalink) Old 12-30-2006, 01:36 AM Thread Starter
Pickguard Advice?
So, I have to replace the pickguard on my RG2550 to make it work correctly with the sustainiac stealth plus I've had installed in it.
Any suggestions? Anything mirrored or with a foil backing is out.
I'm mostly looking for cosmetic opinions!
Thanks much
Bahamut is offline
post #2 of 7 (permalink) Old 12-31-2006, 02:45 PM Thread Starter
Re: Pickguard Advice?
Does anyone happen to know of an aftermarket pickguard that will fit it? I'm looking at ordering a replacement RG1550 pickguard from ibanez.. It looks like the holes line up fine but its hard to tell.
Thanks!
Bahamut is offline
post #3 of 7 (permalink) Old 12-31-2006, 07:02 PM
Thanks!
Try Pickguard Paradise (banner above).
Regards
André
fettouhi is offline
post #4 of 7 (permalink) Old 12-31-2006, 10:25 PM
Dee
Or get someone like Jeannie Pickguards to make you one. Send in your current guard and have them copy it. http://home.comcast.net/~pickguards/index.htm
Dee is offline
post #5 of 7 (permalink) Old 12-31-2006, 10:47 PM Thread Starter
Well, I've already ordered the RG1550 guard, for pure simplicity's sake. I'd rather just order a replacement and roll with it than try to decide between 2000 different designs and remove all the hardware from the one I have, send it in, wait for the new one to be cut, shipped, hope it fits... etc. If nothing else, guitar center will take it back if it doesn't fit.
So, if anyone knows if it'll fit, i'd be most grateful.
Thanks!
Bahamut is offline
post #6 of 7 (permalink) Old 12-31-2006, 11:15 PM
Dee
I'm not sure. Isn't the 2550 neck a couple of mm wider at the top of the neck? You might have to hack a little bit off, but I think otherwise it'll work.
BTW, you don't have to look through 2000 designs, just tell them what you want and have them make it. The choice is yours, though. But of course it'd fit, it would be exactly the same fit as your current plate, IE; perfect.
Dee is offline
post #7 of 7 (permalink) Old 01-30-2007, 11:26 PM
There should be no difference between 1550 and 2550 pickguard shape. WD is another company that will duplicate any pickguard in almost any material.
albee1952 is offline
jeannie pickguards , pickguard paradise , sustainiac stealth plus
Clear Pickguard shielding, QUICK HELP! Gex Pickups & wiring 7 06-02-2006 07:27 PM
Jem 90th metal replacement pickguard philzeta Ibanez JEM, UV, JS & Other Signature Models 12 07-20-2003 11:15 PM
pickguard 90th vs UV777PBK,7DBK & 7BSB tony777 Ibanez JEM, UV, JS & Other Signature Models 1 06-12-2003 10:02 AM
Disappointed with pickguard - Jeannies Scoff X Tech: Setup, Repairs and Mods 3 03-26-2002 12:28 AM
DSY swirl pickguard advice - what color to use? jemsite Tech: Setup, Repairs and Mods 8 05-02-2001 10:31 AM
