Pickup choise for tuning to Drop G? - Jemsite
post #1 of 46 (permalink) Old 12-12-2006, 10:43 PM Thread Starter
i´m completely stuck on this...
i might be getting an Ibanez RG7321, and i´m gunna tune it down to Drop G, in other words tune it to A flat (à la KoRn) and then drop the low A string a step down (just so you know what i´m talking about)
i want a DiMarzio humbucker for the bridge position that can keep it´s tightness when playing the deepest strings, i have almost a phobia for muddy sound...
AND i´m not a big fan of scooped sound, i like nice fat midtones
(say, KoRn´s ´´Take a Look in the Mirror´´ album.)
any suggestions?
i´m going to play heavy stuff, as if that wasn´t obvious enough... somewhere along the lines of Fear Factory, Meshuggah, KoRn... you know the kind...
i´m not a soloist, so steve vai-style pickups won´t be nessescary :P
i´m extremely thankfull for any help, you might be the cure for massive headaches! :P
btw, i´m tired, so spelling and everything is horrible, i know :/... and i know i spelled it ´´choise´´:P
MF_Kitten is offline
post #2 of 46 (permalink) Old 12-12-2006, 10:57 PM
Re: Pickup choise for tuning to Drop G?
Well, I personally favor the D-Sonic 7. The PAF7 is also good for that kind of stuff. Late Korn was a PAF7 in a mahogany bodied guitar.
technomancer is offline
post #3 of 46 (permalink) Old 12-13-2006, 12:07 AM
i think if you are tuning that low, no matter what kind of pickups you get, it will sould like [email protected]
C.Thep is offline
post #4 of 46 (permalink) Old 12-13-2006, 12:10 AM
I have Blazes in my Schecter 7 (25.5" scale) in drop G and it sounds pretty good. YMMV
Demiurge is offline
post #5 of 46 (permalink) Old 12-13-2006, 02:27 AM
You could also get a Lundgren. Meshuggah use them. They're very clear sounding and since you're tuning so low you'll probably need a less muddy pickup. They're quite expensive though (around 195 euros).
Check the 7 string model here:
http://www.lundgren.se/index.asp?folid=22&micid=88
The D-Sonic 7 sounds quite good for such a low tuning too and it's less expensive.
Aris_T is offline
post #6 of 46 (permalink) Old 12-13-2006, 03:16 AM
something that low and I'd go with actives. EMG's would be a good choice. Before everyone condemns me for suggesting active pickups let me say this. EMG's might sound sterile to some (if you use two 9 volt batteries wired to 18 volts they acually get A LOT better dynamics) they have a HUGE frequency spectrum compared to passive pickups so drop G tuning will definitely sound a lot tighter on an active pickup than a passive.
RSVampire is offline
post #7 of 46 (permalink) Old 12-13-2006, 09:35 AM
To be correct, Korn tunes to A. A-flat with a dropped bottom string would become drop F#.
As far as pickups go, you've got quite a few choices, apparently. I'll put in a good word for the Blaze Custom - just for checking, I tuned my RG7321 down to sub-octave E, strung with a 68 on the bottom, with suprisingly good results on string-tension, and the sound as well. Definitely playable, and the sound was beefy and defined as well, since the Blaze Custom has loads of midrange.
Roland is offline
post #8 of 46 (permalink) Old 12-13-2006, 10:41 AM
jaxadam's Avatar
I couldn't have said it better myself.
I always thought EMG's sounded good, but they sound great with two batteries.
I would check out an 81-7, or Lundgren M7.
jaxadam is offline
post #9 of 46 (permalink) Old 12-13-2006, 11:06 AM Thread Starter
Well, i don´t want the Lundgrens, they´re both too expencive, and not my taste (too scooped), and i´m sorry, but i simply don´t like EMG´s... i´ve tried many, but they´re not my thing... i like passive pickups...
so yeah... i´m not shure about the tuning thing, but it´ll either be drop G or drop F then... anyways, it´s not too different...
well, i´m narrowing down the whole range that i´m looking at right now, so...
anyone have suggestions for which 7-string dimarzio´s i SHOULDN´T get? :P like one´s that´ll just be pure mud?
and to the guy that said it would sound crap, well, that´s a matter of opinion now, aint it?
post #10 of 46 (permalink) Old 12-13-2006, 11:16 AM
remember to use heavy strings! over .60 for the low G...
NaHuELoidE is offline
post #11 of 46 (permalink) Old 12-13-2006, 11:29 AM
I would say D-Sonic and some sufficiently heavy strings. Perhaps you might want to look at Schecter 7-string models which are usually an inch longer to cater for any loss of tension. Ideal for whatever tuning you want.
NeglectedField is offline
post #12 of 46 (permalink) Old 12-13-2006, 12:37 PM
An .068 works just fine - you could try going up to .070 if you want even more tension. Assuming you've got a Korean RG7321, .070 is the maximum upper limit gauge you can use without modifying the guitar. A friend of mine who's got an Indonesian RG7321 says that an .068 will not fit without at least drilling the tuner.
Roland is offline
post #13 of 46 (permalink) Old 12-13-2006, 02:55 PM
Get the D-Sonic then! And heavier gauge strings! Enjoy!!!!
Aris_T is offline
post #14 of 46 (permalink) Old 12-13-2006, 03:32 PM
might be worth hunting out a baritone 7 string to get a good G out of it.
timi_h is offline
post #15 of 46 (permalink) Old 12-13-2006, 08:31 PM Thread Starter
hmm... sounds nice, sounds nice... i already had the D-sonic in mind too, so looks like we have a winner
also, i´m going for a .65 or .68 or even a .70 for the G-string (hah!)
i love Ibanez, and i want a fixed bridge... so the 7321 is great for me, with the lovely Wizard neck that i love...
and i don´t like lower-end schecters, and i can´t afford the higher end, so...
New question though, how would the Tone Zone 7 perform as a neck pickup? it´s either that one or the Air Norton 7 for the neck pickup...
air norton , amp distortion , blaze neck , bridge pickup , bridge position , dimarzio air , dimarzio air norton , dimarzio blaze , duncan invader , ernie ball , fixed bridge , fretboard wood , gauge strings , neck pickup , neck position , seymour duncan , steve vai , tight bass , tone zone , wound strings
Breed bridge PU: describing the mids Ced777 Pickups & wiring 13 04-19-2004 04:49 PM
Pickup adjustment problem. RG-Head Tech: Setup, Repairs and Mods 2 01-29-2004 04:47 PM
Drop tuning pickup Jammy Pickups & wiring 8 08-22-2003 06:00 AM
Parker Fly owners, pickup info. bammbamm Pickups & wiring 6 02-11-2003 09:35 AM
Pickup Issue.. - Problem with wiring? MrBungle Pickups & wiring 5 04-15-2002 09:03 PM
