Play in Original Edge Bridge. - Jemsite
post #1 of 9 (permalink) Old 05-28-2015, 05:24 PM Thread Starter
Hi everyone, first post here with a short question..
I just bought myself an RG652AHM NGB. It's my first Prestige model and first 'expensive guitar' so I'm thrilled to bits.
There's just a small issue with play in the Original Edge bridge. Lowering the tremolo arm (lowering pitch) and then releasing it slowly back to resting point will leave the guitar in an ever so slightly lower tuning than if you were to raise the bar and then let it fall to resting point.
The difference looks like 0.3 of a semitone on my tuner and is pretty much uniform across the strings, but it is still noticeable when playing along to a piece of music or backing track.
Is there anything I can tighten to prevent this?
If it's of any significance, it had a long trip from Japan over to the UK.
Thanks in advance
BigOneEye is offline
post #2 of 9 (permalink) Old 05-28-2015, 07:57 PM
Re: Play in Original Edge Bridge.
Congrats on your new guitar!
Did you lock the studs down? Another great thing to do is put a bit of lubricant on the studs where they contact the knife edges. Make sure the bridge is aligned like the pictures that Rich has up on his Ibanez Rules site.
PBGas is offline
post #3 of 9 (permalink) Old 05-28-2015, 08:57 PM
Sweet! That is a nice guitar! Congrats...
Make sure the trem is nice and level, especially after it's long trip to a new climate. The knife edges should be parallel to the strings and body, you can see them on the sides of the trem body. Seems to make a little difference in the trem going back to the exact same point.
I've had guitars that did that even after leveling and lubricating, so another habit I've developed is to always give the trem a little dip periodically when tuning... then after using the trem when playing. So I always leave it in the same position as when I tuned it. I hope that makes sense. Seems to help... but it's just a habit I developed from having less than perfect tremolos in the past.
FireEagle is offline
post #4 of 9 (permalink) Old 05-29-2015, 10:39 AM
It's probably that the studs aren't locked down, all Ibanez guitars I've bought from new have had them not locked down by default. I think they sent an allen key of the correct size in the case, for me.
Craig_Shaft is offline
post #5 of 9 (permalink) Old 05-29-2015, 05:44 PM
stretch (the strings) like your life depends on it, I do various torture methods on strings to get them to stay in pitch, and I do then a long time too. Lube your knife edges with Chapstick brand original Chapstick and graphite, lock your locking studs down, stretch the springs a bit by doing divebombs and pull ups, make sure to lock your nut down firmly but not too tight
Kyle am I is offline
post #6 of 9 (permalink) Old 05-30-2015, 01:08 PM
I have had the same problem on some old Floyd Rose Guitars, and the solutions were replacing the springs with new springs for more tension, or adding an extra spring or two.
Since your Guitar is new, a proper setup should do the trick.
If you don't get the problem solved, please spend the extra money, and get a professional setup. Otherwise you will never be happy with your Guitar.
Mrocker is offline
post #7 of 9 (permalink) Old 05-30-2015, 03:17 PM Thread Starter
Thanks for all of your replies!
Thanks for pointing me in IbanezRules' direction, PBGas. I used to visit the site just to see the NAMM photos each year, but never dug deep into the tech help. There is a page on exactly this problem!
With regards to the locking studs, I tried fiddling with them but the allen key seemed to endlessly rotate and not loosen or tighten anything at all (yes I used the correct size key! :P)...I didn't even know they existed until the replies here!
The trem is angled slightly up from the body like it should be and the strings are stretched.
I think a professional setup is probably the best remedy.
post #8 of 9 (permalink) Old 05-30-2015, 08:46 PM
Glad you found some good info! We should all regularly thank Rich for his site!
They sometimes have those threads all the way up so when the allen key fits into the studlock, you will be turning for a while until it bottoms out.
No worries though, a good setup is always something that will help!
Congrats again on the new guitar!
PBGas is offline
post #9 of 9 (permalink) Old 06-03-2015, 04:09 PM
I've found that tightening the trem springs just ever so slightly will remedy this problem. My RG520 did this as well, it was just a small amount more tension on the springs and it holds in tune like a rock.
wheeler96 is offline
ibanez , original edge , play , prestige , rg652ahm
FS 1986 RG410 MIJ original edge, non original HSC taracatac Classified Ads: Guitars and Gear 2 01-19-2015 07:08 AM
FS: Ibanez Cosmo black Original Edge Tremolo bridge swirl Classified Ads: Guitars and Gear 3 02-04-2014 10:07 AM
WTT: my Gold Schaller FR bridge for your Black Lo Pro Edge or Edge bridge supergirl20_06 Classified Ads: Guitars and Gear 2 08-05-2011 05:57 AM
WTT: Black Original Japanese Edge > Chrome Original Japanese Edge lewis.mann Classified Ads: Guitars and Gear 0 11-23-2008 04:03 PM
wts..original ibz edge bridge qozwayni Classified Ads: Guitars and Gear 1 03-23-2008 01:23 AM
