Please Can You Help. - Jemsite
post #1 of 16 (permalink) Old 11-16-2005, 04:22 PM Thread Starter
Question Please Can You Help.
There has been so many seven string's made & I had ago on a couple dudes.
Now my question is: What the smallest neck dimenshions on an Ibanez 7 srting? Is it the Vai? Is it the others? The one I'm thinking of getting is the 1527 because I think that's got the thinest neck.Am I right?
Could you please help me because this is doing my head in.Cheers.
FRETPICK
FRETPICK is offline
post #2 of 16 (permalink) Old 11-16-2005, 04:43 PM
jim777's Avatar
Re: Please Can You Help.
You might do better with a baritone 6 if you need a neck considerably smaller than an Ibanez 7 neck. The differences between the 7's are in millimeters.
jim777 is offline
post #3 of 16 (permalink) Old 11-16-2005, 04:46 PM
my 7621 felt the thinnest, considerably, vs the rg7ct, uv777bk, and lacs7
1wi11 is offline
post #4 of 16 (permalink) Old 11-16-2005, 05:53 PM Thread Starter
Thanks everyone.Anyone else?
1527?
FRETPICK is offline
post #5 of 16 (permalink) Old 11-16-2005, 07:02 PM
I love the thin ibanez necks, but if they got any thinner you would see the truss-rod.
7Shred is offline
post #6 of 16 (permalink) Old 11-17-2005, 10:23 AM
well...the prestige necks(1527, K7, 8XXX) etc), the UV necks, and 76/742X all have the same radius, neck dimensions...so all should feel about the same...some might be shaped dif (not that i know of) but have the same specs.
The only one different now is the 7321 because it has a wizard II...whis is a little bit rounder in radius and 2mm thicker than the ones listed above.
7stringofablick is offline
post #7 of 16 (permalink) Old 11-17-2005, 10:48 AM
my 7621 is DEFINATELY thinner than my UV777BK
1wi11 is offline
post #8 of 16 (permalink) Old 11-17-2005, 03:47 PM Thread Starter
SO BOTTOM LINE IS THE 1527 is the thinest then? WE HAVE THE WIZARD NECK,WIZARD II NECK,SUPERWIZARD THATS NOT ON ANY 7 STRING.
SO WHAT'S THE THINEST?
FRETPICK is offline
post #9 of 16 (permalink) Old 11-17-2005, 04:20 PM
i played a k7 a while back and the neck on that was pretty thin, my 7321 neck (despite being the 'cheap' model) is very nice to play also.
just out of curiosity are you new to 7's? 'cause you sound a little worried about the transition from 6 strings to 7, if this is the case its best if you tried one out in a shop first but dont fret about it to much ibanez necks are great, hell i even prefer my 7321 to my more upmarket models most of the time
Mr. S is offline
post #10 of 16 (permalink) Old 11-17-2005, 04:32 PM
I have a RG570 with the super wizard, which is the thinest neck Ibanez ever produced. But I am not sure about the 7, maybe RG7620 neck.
7Shred is offline
post #11 of 16 (permalink) Old 11-19-2005, 09:40 AM
I still stand by the fact that all the above mentioned necks (pretty much any japan made seven string) all have the same neck dimension...check the sites and specs...can't really deny that. Some may have a dif feel/shape, but all have the same demensions as a standard Wizard.
post #12 of 16 (permalink) Old 11-19-2005, 01:40 PM
Flobanez's Avatar
The neck on all my Ibanez 7s feel just right.
Flobanez is offline
post #13 of 16 (permalink) Old 11-19-2005, 02:18 PM
The neck on my RG1077XL is pretty thin not as thin as on my Jem 555 though.
Regards
André
fettouhi is offline
post #14 of 16 (permalink) Old 11-20-2005, 07:11 AM
You ask us, what you might think is the nicest neck for you????
Why don't you find out yourself.
But with secondhand RG7620 or RG1527 you simply can't go wrong. Getting new RG1527 you have advantage of new 5 piece neck that looks awesome.
It more matter of how much money do you have to spend, what type of neck do you like.....one piece, 3 piece, 5 piece.......Cause the differences of the different 7 string necks are minor. At least not something that you couldn't get used to. Ibanez are the thinnest necks in the business.......this includes their 7's.
Nuff said. Get yourself one of these and start playing.
Jemmm is offline
post #15 of 16 (permalink) Old 11-21-2005, 02:34 AM
Those 5 piece necks are sweet but I don't like the transition from neck to headstock solely from a optical point of view.
Regards
André
fettouhi is offline
ibanez neck , ibanez necks , neck dimensions , prestige necks , string necks
