PLEASE HELP WITH ZERO RESISTANCE (ZR) TREMOLO !!! - Jemsite
post #1 of 12 (permalink) Old 08-22-2007, 03:24 AM Thread Starter
I'm sorry, this is a really noobish question ! But, the thing is that i recently got a s520ex with ZR trem. Everywhere, i have heard that the tremolo arm is a screw in. But when i tried doing that, it doesn't tighten! I need step by step help please, someone help me. I don't think im missing anything, so i guess i'm just a noob with this style of tremolo. Please help quickly!
sum41punkplaya is offline
post #2 of 12 (permalink) Old 08-22-2007, 04:22 AM
Re: PLEASE HELP WITH ZERO RESISTANCE (ZR) TREMOLO !!!
the trem arm is not a screw in. I thought it had a bushing that has a little allen screw that you tighten with the smallest allen wrench.
OR the bushing itself is the screw-in type.
I could be wrong.
Ibateur is offline
post #3 of 12 (permalink) Old 08-22-2007, 07:14 AM
you have to push it in for a certain amount, then screw while pushing, then just continue screwing
Dreamsower is offline
post #4 of 12 (permalink) Old 08-22-2007, 07:21 AM
Yes what Dreamsower said.
GTR-MAN is offline
post #5 of 12 (permalink) Old 08-22-2007, 07:43 AM
Applies to so many things in life
DavyH is offline
post #6 of 12 (permalink) Old 08-22-2007, 04:34 PM
well put Davy
I checked out this guitar in my local store. Them being a bunch of idiots the trem arm wasnt on the guitar. So they set out to go find it. It took em bout 15 minutes and they came back with something chrome that needed screwing. So I did and eventually it worked.
I quite liked the ZR to be honest. way better then a TRS or those Edge 2s (3?) they stick on Korean RGTs
Youd have make a lot of rounds to actually get it tight tho
mike80sguy is offline
post #7 of 12 (permalink) Old 08-22-2007, 08:03 PM
make sure the arm tightening screw is loosened. used to happen to me to, push it down a bit and it might click, then the arm can be screwed in.
-Rhaab is offline
post #8 of 12 (permalink) Old 08-22-2007, 09:35 PM Thread Starter
Update guys, I looked at the trem arm, and it has two white bushings, and is made of black metal. I don't see any apparent threadings on it, so i'm not sure what im supposed to be screwing.
post #9 of 12 (permalink) Old 08-22-2007, 10:32 PM
jb4674's Avatar
Reviews: 18
Take a picture of the trem and the arm so we can see what you're talking about
Jimmy
jb4674 is offline
post #10 of 12 (permalink) Old 08-22-2007, 11:04 PM
hey dreamsower can i use this as my signature?
spider murphy is offline
post #11 of 12 (permalink) Old 08-23-2007, 02:24 AM Thread Starter
http://img3.***************.com/dbas...0/8/419108.jpg
Everyone, here is an image of what the trem arm loooks like. As you can see,no threads, and I'm not sure if its supposed to go with the ZR system or not .
post #12 of 12 (permalink) Old 08-23-2007, 05:09 AM
I can't see the picture. But if you have a black arm with two white plastic bushings, it's not the correct arm.
the ZR trem arm is threaded!!
It is a screw in arm, with adjustable "stiffness", the latter is done by tightening the cap that goes over the arm.
EL-CeeDee is offline
allen wrench , trem arm , tremolo arm
JEM 555 poor tremolo - I think I've found a solution carlos seo Ibanez JEM, UV, JS & Other Signature Models 20 08-15-2007 10:34 AM
Zero Resistance Tremolo Kemono All Other Guitars (including Prestige) 11 07-17-2006 11:18 PM
Broken ZR tremolo... Is this common?? FastRedPonyCar All Other Guitars (including Prestige) 16 06-01-2006 04:50 PM
Bad Tremolo Diceman Tech: Setup, Repairs and Mods 3 06-01-2005 07:16 AM
Just a question... - about Tremolo Bridge Height Adjustment armindo__dias Tech: Setup, Repairs and Mods 2 11-03-2001 12:20 AM
