Possible bodies RG AANJ neck? - Jemsite
 1Likes
  • 1 Post By sepulchrave
post #1 of 5 (permalink) Old 12-04-2018, 11:06 AM Thread Starter
I have an RG360 with an after-market neck of unknown provenance. I love the neck but would prefer a hardtail so am looking for an alternative body to put it on.
What are the options? Is it only RGs? I know other models have the AANJ thing, but with a different number of frets so presumably won't work. I'm not looking to spend much (any ) money on it so GRGs can be on the shortlist.
And if I don't worry about the AANJ shape, would an RG neck fit in older models - or even non-Ibanez models?
Thanks!
Zerozeddy is offline
post #2 of 5 (permalink) Old 12-04-2018, 11:28 AM
Re: Possible bodies RG AANJ neck?
The RG360 is a fairly rare model:
RG360 | Ibanez Wiki | FANDOM powered by Wikia
By far the simplest and cheapest option for you is simply to block the trem turning it into a hardtail.
Use an accurately shaped block of hard wood to wedge in behind the trem, then remove the springs and wedge another accurately shaped block of the same wood in front of the trem, now replace the springs to stop the claw from rattling about. Voila, a hardtail with fine tuners.
Remove the tremolo arm and the locking pads from the locknut. Keep the parts safe so you can put it back to standard if you want to sell it.
A bit of simple woodwork using any hardwood offcut will take far less time and cost you next to nothing as well as being fun to do as long as don't cut yourself making the wood blocks!
sepulchrave is offline
post #3 of 5 (permalink) Old 12-04-2018, 11:38 AM Thread Starter
My mistake, it's actually a 370 not 360 RG370DX (2003?2004) | Ibanez Wiki | FANDOM powered by Wikia although I imagine your blocking comment still applies.
post #4 of 5 (permalink) Old 12-04-2018, 11:41 AM
Absolutely, the Edge Pro 2 is a low profile design and will make for an even better hardtail once blocked.
jono likes this.
post #5 of 5 (permalink) Old 12-05-2018, 01:41 AM
I have a 1988 360 - owned since 1991. Didn't think there were any still around. Only mod is a Tone Zone in the bridge, still very sweet to play, though it feels tiny compared to my UV71P.
BdaGolfer is offline
aanj , rg360
AANJ neck compatibility on MIJ bodies faekildare All Other Guitars (including Prestige) 0 09-29-2012 10:38 PM
1 pc. bodies vs. 2 pc. bodies Myst and rain Tech: Setup, Repairs and Mods 24 01-01-2009 01:42 PM
WTT: Non AANJ UV neck for AANJ 7-string neck Platypus Classified Ads: Ibanez JEM/UV Guitars 0 11-15-2004 10:14 AM
JEM & UV Bodies - JEM & UV Bodies sebastian Ibanez JEM, UV, JS & Other Signature Models 15 07-18-2001 11:23 AM
Necks and Bodies - Necks and Bodies sebastian Ibanez JEM, UV, JS & Other Signature Models 20 03-29-2001 10:50 AM
