To Presige or not prestige??? - Jemsite
post #1 of 13 (permalink) Old 01-21-2006, 03:37 PM Thread Starter
Hi guys, i'm after an ibanez RG neck for a project i'm working on, (aswell as Bridge, hardware etc).
I popped into a local guitar shop today, and i had a go on an RG 2620, and a 350DX, just to see if i could feel the difference really.
Well... I could. i cant put my finger on what the difference was, but the 2620 just played SO much better!
am i correct in thinking the 2620 has a Wizard neck and the 350 a wizard 2 neck? the neck on the 2620 did feel thinner, but there was more to it than just that, it seemed nicer overall.
Since for my project, i need everything except the body, i was thinking it would probably be easier (and cheaper) to buy a used RG with maybe the odd mark on the body, and use all the parts from that.
I have done a bit of research, that shows that the old RG5xx series used the wizzard neck too.
do the necks from the RG5xx feel as nice as these prestige models? as buying a prestige guitar to rip apart would be quite expensive, although i do quite like the look of the Edge Pro bridge.
The donor guitar MUST have some damage to the body, i couldnt bring myself to rip apart a perfect guitar.
so what are your thoughts guys? which necks would be the ones to go for?
Thanks guys
Andy
champ222 is offline
post #2 of 13 (permalink) Old 01-21-2006, 03:56 PM Thread Starter
Re: To Presige or not prestige???
Also, the neck must have the All access neck joint, does any one know when they started putting these on the RGs?
Cheers
Andy
champ222 is offline
post #3 of 13 (permalink) Old 01-21-2006, 04:44 PM
Cheers
Andy
1993 did the AANJ appear.
Regards
Andr
fettouhi is offline
post #4 of 13 (permalink) Old 01-21-2006, 05:17 PM
Look around for a used RG1570. They're Prestige guitars (actually they're the transition of the 570 to a Prestige model) and you can find them for ~$500 used.
technomancer is offline
post #5 of 13 (permalink) Old 01-21-2006, 07:00 PM
Yeah, I would say to look around for either a later model RG550 or 570 with an AANJ or the 1570 used. "Evilbay" is probably the best bet as they pop up on their quite frequently.
lyconxero is offline
post #6 of 13 (permalink) Old 01-22-2006, 08:32 AM Thread Starter
thanks guys, would i get a similar feel then from an RG5xx series, as i would from a newer prestige neck?
thanks
Andy
champ222 is offline
post #7 of 13 (permalink) Old 01-22-2006, 09:13 AM
Similar, yes.
post #8 of 13 (permalink) Old 01-22-2006, 09:38 AM
Not really, the Wizard Prestige necks are a bit thicker than the pre-03 Wizard. Also, the feel of the Prestige neck is supposedly worn-in due to the extra finishing steps.
King Knall is offline
post #9 of 13 (permalink) Old 01-22-2006, 05:30 PM
He asked if they were "similar" not the same. Also, the only guitars that you're going to find with a pre-03 wizard neck would be used so it WOULD most likely already feel worn-in. But like everything else, I always say to play before you pay; otherwise you may get burned (although I haven't met the person who's played an Ibanez RG550 and NOT liked it; I really wish I had one myself).
But seeing as to how both the RG550s and 1570s can be found used, you might just want to look for a 1570 instead if you can't find a 550 or 570 to demo.
post #10 of 13 (permalink) Old 01-23-2006, 06:13 AM Thread Starter
ok thanks guys
thats a great help
champ222 is offline
post #11 of 13 (permalink) Old 01-23-2006, 01:15 PM
You'll feel a dif...but i think it's so small (maybe 1mm at both the 1st and 12th frets) that it won't be huge. Plus, the back of the RG5 had a laminated feel to it, whereas the new ones have a smoother 'sanded' feel. Both play amazing...
7stringofablick is offline
post #12 of 13 (permalink) Old 01-24-2006, 04:16 PM
do it i love them
guitarshredder7 is offline
post #13 of 13 (permalink) Old 01-24-2006, 04:39 PM
thanks
Andy
It's close. The older ones are even thinner.
red5 is offline
access neck joint , edge pro bridge , guitar shop , local guitar shop , neck joint , prestige guitar , prestige guitars , prestige necks , wizard prestige , wizard prestige neck
FS: J-Custom, 2 Piezo Prestige's, A black prestige and a JS SYL Classified Ads: Guitars and Gear 4 09-21-2013 08:05 AM
Prestige RG3120 or Prestige S1540 ??? StefanosD All Other Guitars (including Prestige) 7 01-31-2011 12:20 PM
Prestige parts on a non prestige ibanez sirshredsalot Tech: Setup, Repairs and Mods 3 09-25-2010 02:16 AM
FS/FT - Mint 8 Strings Prestige Ibanez Prestige RG2228-GK (EUROPE) DI0H Classified Ads: Guitars and Gear 1 04-26-2010 09:27 AM
New/Used Presige for me CosmicDebris All Other Guitars (including Prestige) 13 11-13-2007 06:31 PM
