Prestige case help.. - Jemsite
post #1 of 7 (permalink) Old 02-19-2011, 05:24 PM Thread Starter
I recently picked up an older RG3120, minus the original HSC. There are a bunch on the auction site, but with all different nomenclature, i.e. CS-0593, CS-0560 etc. This confuses me in the sense that this RG seems to be identical to all the others ive played. I dont want a generic Ibanez case, or SKB or whatever.
Besides the obvious differences such as scale length, reverse headstock or being a Saber, whats with all the different numbers?
I just want a TJC Case. Any advice?
metalguy is offline
post #2 of 7 (permalink) Old 02-19-2011, 05:52 PM
RGTFanatic's Avatar
Re: Prestige case help..
this is the case you want. The CS numbers are just the sellers stocking numbers and have nothing to do with Ibanez part #'s.
item #300525757975
BTW... all of that sellers cases are identical, other than condition
RGTFanatic is offline
post #3 of 7 (permalink) Old 02-19-2011, 08:48 PM Thread Starter
Thanks man
metalguy is offline
post #4 of 7 (permalink) Old 02-20-2011, 07:27 AM
Any RG TJC case will fit,just each model is fitted with matching case.
So just don't buy a TJC case from a JS/S etc,RG only which is easy to tell when you look in the case(RG shape).
corey j grieve is offline
post #5 of 7 (permalink) Old 02-20-2011, 12:31 PM
Is there a fitted case for an RG with a square heel neck? I'd like to get something a little nicer for my old RG550.
van01010100 is offline
post #6 of 7 (permalink) Old 02-20-2011, 02:14 PM
There is,the latest PGM RG and the southern cross RG(australian limited model).
So wont be an easy find.
Most people modify the aanj versions by using a hammer and gently reshaping that area,the foam can be flattened and reshaped quite easily with some gentle persuasion. I believe Rich (dealer on this site) said this is all Ibanez did for the re issue square heal models,its also possible to gently cut through the red fur at the base,peel up enough to get to foam, remove desired foam to allow fit and re glue down.I've done this with great results,its all actually quite easy,the foam is easy to remove.
post #7 of 7 (permalink) Old 02-20-2011, 02:39 PM
That's what Ibanez did on the RG770 cases. It doesn't come out very well, not the ones I've tried. The JS case is specific and formed for the plat joint, but of course will not work on RG's.
Rich is offline
case , ibanez , prestige
Prestige Jem RG Case mr-skid Classified Ads: Guitars and Gear 1 09-28-2010 04:34 PM
Prestige Case mr-skid Classified Ads: Guitars and Gear 5 09-28-2010 03:57 PM
fs/ft prestige case rob777vdy Classified Ads: Guitars and Gear 6 05-20-2009 10:55 AM
Prestige Case bnosam All Other Guitars (including Prestige) 1 05-22-2008 03:27 AM
Where can you buy a Prestige case? TheJazzTerminator All Other Guitars (including Prestige) 34 07-12-2006 09:49 AM
