prestige case question - Jemsite
post #1 of 3 (permalink) Old 03-23-2011, 07:08 PM Thread Starter
Question prestige case question
Hi,
Does anybody know if it is possible to tighten a loose bottom stud on a prestige case?
The case I got along with my RGA had a bottom stud that seems to be loose, I can move it a little bit and I tried tightening it just by turning it, but that did not do anything.
I'm afraid the stud will come off after a while, so I was wondering if it's possible to tighten it.
Is there a counter screw on the other side? If yes, how can I access it?
Thanks,
Lars
Santuzzo is offline
post #2 of 3 (permalink) Old 03-24-2011, 09:03 PM
Re: prestige case question
You mean the latches? You'll need stuff like rivet guns...
For the most convenience, just take it to a luggage repair shop.
Blacksabba is offline
post #3 of 3 (permalink) Old 03-25-2011, 03:14 AM Thread Starter
Thanks,
No, I'm talking about the bottom studs, on which the case stands, not the latches.
I think the studs are not tightened with nuts/screws but indeed as you said with rivets.
Santuzzo is offline
prestige case
Prestige case help.. metalguy All Other Guitars (including Prestige) 6 02-20-2011 02:39 PM
Prestige Jem RG Case mr-skid Classified Ads: Guitars and Gear 1 09-28-2010 04:34 PM
Prestige Case mr-skid Classified Ads: Guitars and Gear 5 09-28-2010 03:57 PM
fs/ft prestige case rob777vdy Classified Ads: Guitars and Gear 6 05-20-2009 10:55 AM
Where can you buy a Prestige case? TheJazzTerminator All Other Guitars (including Prestige) 34 07-12-2006 09:49 AM
