Prestige neck bolt issue - Jemsite
post #1 of 8 (permalink) Old 10-17-2010, 11:22 PM Thread Starter
Just acquired a RG2006. Really an amazing player.
I noticed today the two neck bolts closest to the trem cover are not tightened all the way down. One is high enough to let the washer spin and move up and down. It is about 1/16 to 1/8 high, but does not protrude past the bolt hole.
I am tempted to tighten them, since it makes sense to me that the stress is supposed to be spread over all four of the bolts. But I really do not want to ruin the supernaturally low action.
Has anyone seen this before? Leave them or tighten? Any advice would be greatly appreciated.
klegg is offline
post #2 of 8 (permalink) Old 10-17-2010, 11:36 PM
Re: Prestige neck bolt issue
I would tighten them down. I don't see how they would affect anything by being loosened. At the same time when tightening make sure you don't have to use TOO much force or you might be going through the fretboard. That's unlikely since that normally happens when you get the back screws mixed with the front since the back are longer than the front screws.
That's my take on it but maybe someone else can confirm.
kylendm is offline
post #3 of 8 (permalink) Old 10-17-2010, 11:51 PM
Reviews: 98
Tightern them down. In fact, loosen all four screws--then tighten them all down.
AlaskaBat is offline
post #4 of 8 (permalink) Old 10-18-2010, 07:00 AM
Reviews: 9
If the neck isn't actually lifted off the body in the pocket, it won't affect your action. If it is, you can always take the neck off and shim it, though shimming the pocket of the neck nearer the bridge is equivalent to lowering the bridge studs.
Fun111 is offline
post #5 of 8 (permalink) Old 10-18-2010, 08:50 AM
If it's the two screws closed to the brigge that are affected the force of the strings will act to pull the heel of the neck into the neck pocket, pivoting on the fulcrum formed by the other two screws. just tigthen the two lose screws and your action will not be affected.
adriandavidb is offline
post #6 of 8 (permalink) Old 10-18-2010, 06:43 PM Thread Starter
Thanks for the suggestions. It is the bolts nearest to the bridge. I am going to tighten them down when I get home.
klegg is offline
post #7 of 8 (permalink) Old 10-29-2010, 09:53 PM Thread Starter
I went ahead and tightened the bolts down. not too tight, just snug. Slight buzz now on the low E. Noticed it the day after, so it may be weather related.
klegg is offline
post #8 of 8 (permalink) Old 10-30-2010, 07:13 PM
I once loosened the two top bolts (toward the headstock) expecting the string tension to pull the nut away from the body slightly raising the string action. Prolly not a recommended procedure.
jer3d is offline
lose bolt. , prestige neck
Bolt On vs Neck-Thru adil2552 Tech: Setup, Repairs and Mods 10 07-22-2011 11:03 PM
S5470 Prestige Issue GuntherLust All Other Guitars (including Prestige) 4 02-15-2009 01:25 PM
Bolt-on VS neck-thru hollow125 Ibanez JEM, UV, JS & Other Signature Models 17 06-09-2007 10:49 PM
prestige RG bolt-ons rguser All Other Guitars (including Prestige) 3 02-03-2006 05:54 PM
New Neck-Through vs Bolt-On The_Grindfiend Tech: Setup, Repairs and Mods 22 09-06-2004 01:36 AM
