problem with floyd on rg1077xl - Jemsite
post #1 of 22 (permalink) Old 02-09-2006, 06:39 PM Thread Starter
have a little "problem" with my floyd. When i pull up on the bar, so the pitch goes up, and then lets go, so it returns to normal pitch, the tuning is a bit off. Not much, just a tad higher on some of the strings. However, when i dip the bar after that (so the pitch go down), and then release the pitch is normal again. I was thinking that it might be the Knife-edges?
help?
new_breed is offline
post #2 of 22 (permalink) Old 02-09-2006, 06:59 PM
Re: problem with floyd on rg1077xl
Nup, unless its noticably out of tune (quite a bit) thats very normal for a floyd equipped guitar. Congrats on the awesome guitar as well!
ibanez.shredder is offline
post #3 of 22 (permalink) Old 02-10-2006, 02:54 PM
Make sure your trem studs are locked, too, and your strings are properly broken in. Rather than filing the knife edges, though, start by lubricating the trem contact points - as a mountian biker, I use Pedro's Extra Dry chain lube - works like a charm.
As long as it's only a cent or too, you're probably fine - this is typical of Floyds.
Drew is offline
post #4 of 22 (permalink) Old 02-15-2006, 12:48 PM Thread Starter
Well it gets noticably out of tune, chords sound like ****
what do you mean by "strings are properly broken in"
thanks!
post #5 of 22 (permalink) Old 02-15-2006, 01:10 PM
Reviews: 7
He means stretch them, strings can stetch up to an inch from when they are put on to when there are finished stretching. Without stretching them a floyd is useless.
brothersnowgone is offline
post #6 of 22 (permalink) Old 02-15-2006, 05:48 PM Thread Starter
well i donīthink thatīs the problem, cause iīve had the strings on for some time, and when i pull the tremback down (divebomb) itīs in tune again!
post #7 of 22 (permalink) Old 02-26-2006, 01:03 PM Thread Starter
Unhappy Re: problem with floyd on rg1077xl
please help!
should i file the knifes? or buy new?... what else could be wrong?
It almost goes out of tune by a half tone!
post #8 of 22 (permalink) Old 02-26-2006, 02:49 PM
Read the tech section at ibanez rules (banner above) .
Regards
André
fettouhi is offline
post #9 of 22 (permalink) Old 03-14-2006, 07:31 PM Thread Starter
well i did and i still canīt find whatīs wrong
Oh, another problem iīm having is this....
I tune toi Bb ok, thatīs not low right?...it is a baritone...
But i just canīt get the intonation right on the 7th string, i need the string to be longer (the pitch is to high when i fret at 12th fret)
How can this be?
I thought that a baritone was the sulotion to this... since the scale is longer?
post #10 of 22 (permalink) Old 03-16-2006, 01:10 PM
Have you adjusted your intonation? A extended scale can help intonation on lower tunings, but you still have to have it intonated correctly.
Drew is offline
post #11 of 22 (permalink) Old 03-20-2006, 08:28 AM Thread Starter
well yes of course:P
i canīt move the saddle any further back, thatss my problem...
post #12 of 22 (permalink) Old 04-15-2006, 03:12 PM
you can affect the intonation also by adjusting action, make the string higher or lower
VaLDeZ is offline
post #13 of 22 (permalink) Old 04-15-2006, 06:59 PM
Reading ibanezrules advice and advice on here,strings should be fully stretched BEFORE locking down the nut,so even if they've been on for a while it wont matter if they weren't properly stretched first.
andy7jem is offline
post #14 of 22 (permalink) Old 04-20-2006, 07:42 PM
hijack... sorry
question about the 1077/2077 xl, was it discountinued?
fazrul_x2n is offline
post #15 of 22 (permalink) Old 04-20-2006, 09:11 PM
Yes, they ceased making them in '02 & '04 respectively. Details here:
http://www.jemsite.com/ibanez/spec_ib7.htm
Awakened Sleeper is offline
equipped guitar , esp arming adjuster , trem studs
lo-pro floyd problem ravselj All Other Guitars (including Prestige) 12 01-12-2012 08:28 PM
Gotoh Floyd problem :( Shredcows Tech: Setup, Repairs and Mods 6 11-07-2005 12:25 PM
Floyd Rose setup on a RG1077xl?? Requiem All Other Guitars (including Prestige) 1 02-26-2004 10:37 PM
