Problem on the G and the B string - Jemsite
post #1 of 48 (permalink) Old 11-06-2011, 11:07 AM Thread Starter
Angry Problem on the G and the B string
Hi, i have a washburn guitar with a licensed floyd rose. The problem that i have is when playing notes only on the G and the B strings starting from the 15th and until the 24th fret, when i fret the notes i get this irritating sound (like its not intonated or like 2 notes are played together but they dont sound good with each other) and some notes die quickly! ... its really killing me! i have tried everything the floyd is strait with the bod, i adjusted the intonation, changed the stings, adjusted the action and the truss rod but its still the same!
should i consider changing the floyd? or should i try using the Groove Fat Finger, i read something on the internet thats it could solves some problems ...
any ideas ??
thanks!
RICHO is offline
post #2 of 48 (permalink) Old 11-07-2011, 02:15 AM
Re: Problem on the G and the B string
If you don't find an answer on the internet, you might consider taking it to your local guitar shop, if the problem isn't too big they should repair it for cheap.
OMFG Zero FTW is offline
post #3 of 48 (permalink) Old 11-07-2011, 02:18 AM Thread Starter
i went to the biggest guitar shop that we have, they tried to set the neck the the bridge height but nothing changed :S
RICHO is offline
post #4 of 48 (permalink) Old 11-07-2011, 02:23 AM
Sounds to me like one of, what we call chair contractors in Norway, is lose or broken in the tremolo.
What kind of tremolobridge exactly is it?
Norstorm is offline
post #5 of 48 (permalink) Old 11-07-2011, 02:46 AM Thread Starter
its the same model as this one but made by washburn:
#jm#otakusekaii.files.wordpress.com/2009/08/94___schaller-floyd-rose-tremolo.jpg
just put instead of the #jm# ... http
RICHO is offline
post #6 of 48 (permalink) Old 11-07-2011, 03:02 AM
I retract my previous statement. That bridge doesen't have them..
Hmm.. I bet my life the problem is somewhere on the netlock or the bridge.
Sounds like when the string vibrates, it nudges something lose..
Since the action and fretbuzzing seems to be outta way, have a look and do some tests with the bridge and the nut.
Norstorm is offline
post #7 of 48 (permalink) Old 11-07-2011, 03:09 AM Thread Starter
i am considering buying a new schaller tremolo ... i really hope that will fix problems and not just waste the money
RICHO is offline
post #8 of 48 (permalink) Old 11-07-2011, 03:13 AM
That's when testing and the ellimination progress comes in handy
*forgive my rusty english*
Norstorm is offline
post #9 of 48 (permalink) Old 11-07-2011, 06:52 AM
Get the fret level checked. You may have uneven frets at the top of the neck. A lot of guitars will ship from the factory with very little setup work done on the frets, and you can find that a new guitar may need the frets filed. If there any high spots, the strings might be touching them when they vibrate, which would certainly cause them to die out quickly. And the further up the neck you go, the steeper the string angle is, so it could explain why it only happens after the 15th fret.
Mark_McQ is offline
post #10 of 48 (permalink) Old 11-07-2011, 06:54 AM
I thought that was elliminated?
If not, forget about about your tremolo and nut... Do this FIRST. unwanted fretbuzz is a pain. Maybe you just need a partial fretdress.. Done in a flash.
Norstorm is offline
post #11 of 48 (permalink) Old 11-07-2011, 07:34 AM Thread Starter
thnx for all the fast replies ... i tried to check them myself but i didnt find anything ... maybe im not an expert but ill try to get it done by a guitar shop or smthn .. thnx for the hint!
RICHO is offline
post #12 of 48 (permalink) Old 11-07-2011, 07:40 AM
Hope you nail it without spending to much cash..
Good luck bro
Norstorm is offline
post #13 of 48 (permalink) Old 11-07-2011, 08:34 AM
It sounds like the frets to me.
If you raise the bridge higher than you like it, does the sound go away?
sebastian is offline
post #14 of 48 (permalink) Old 11-07-2011, 08:40 AM Thread Starter
i really tried to play with a high action but nothing has changed ... and if the frets are the problem ... why only the notes on the B and the G string ?
RICHO is offline
post #15 of 48 (permalink) Old 11-07-2011, 09:00 AM
I can't understand the issue or sound you are trying to tell us about.
floyd , problem , rose , string
Steinberger string problem necromancer69 All Other Guitars (including Prestige) 9 01-06-2011 04:57 PM
1st string problem sixstring Ibanez JEM, UV, JS & Other Signature Models 8 07-01-2010 12:46 PM
G string problem, please help ! Professor Jones Tech: Setup, Repairs and Mods 9 01-22-2006 12:35 PM
String Problem! Help! The Wood Tech: Setup, Repairs and Mods 6 07-15-2004 10:00 AM
7th String Sustain Problem The_Grindfiend All Other Guitars (including Prestige) 5 02-12-2004 12:06 PM
