Problem with RG 370 DX - Jemsite
post #1 of 17 (permalink) Old 08-08-2005, 06:10 AM Thread Starter
Reviews: 5
Hello
I bought a Ibanez 370 DX recently
Everything in tip top shape but when I was changing the gauges of strings from 9s to 10s the tremolo could not handle it and pulled back all the saddles.
Is it possible to run a set of 10s?
Ho do I adjust the saddles and inotation of the guitar accurately.
Cheers
Wildchild
wildchild247 is offline
post #2 of 17 (permalink) Old 08-08-2005, 08:05 AM
Re: Problem with RG 370 DX
Check out the tech section at ibanezrules.com
You'll to adjust the trem springs to keep the bridge parallel to the body and intonation is just a pain in the @ss. But all is explained on the above site
markg5150 is offline
post #3 of 17 (permalink) Old 08-08-2005, 08:41 AM
You shouldn't have to change the intonation at all if you're leaving it in standard tuning. I have 10s on my RG370DX and it took me about 30 minutes to get the trem level, but it wasn't really hard. The backplate gives you easy access to the springs so you just mess around with them (loosening them, then tightening, then tuning) until you get the trem set exactly where you want it.
lyconxero is offline
post #4 of 17 (permalink) Old 08-08-2005, 09:25 AM Thread Starter
Reviews: 5
could the springs be the fault??
they dont seem to have a strong pull on them.
the screws for tightening the trem are almost to the maxand it still doesn't work
post #5 of 17 (permalink) Old 08-08-2005, 10:14 AM
then you can try adding 1 or 2 springs.
damo7v is offline
post #6 of 17 (permalink) Old 08-08-2005, 10:58 AM Thread Starter
Reviews: 5
I have three springs mounted on it, with them all aimed at the center like a claw shape.
It still doesnt do the job.
anybody else have tips on setting the inotation from scratch without any special tools.
I think thats my main problem after the tremolo kinda exploded on me.
lol.
I am running custom 9-46 on them now and trying to tune it but its a bitch.
I also noticed that the springs I got were gold ones, I read they are some hassle.
Does your RG 370 DX have gold or silver springs??
Thanks
Wildchild
post #7 of 17 (permalink) Old 08-09-2005, 11:00 AM
My RG370DX has gold-looking springs, but I haven't had any problems with them. I did trem them a little bit though instead of adding more springs and that seemed to do the trick as far as allowing me to put 10s on the guitar.
post #8 of 17 (permalink) Old 08-10-2005, 08:42 AM Thread Starter
Reviews: 5
What did you do to your springs??
How secure is adding extra springs into the screwholes??
post #9 of 17 (permalink) Old 08-10-2005, 11:06 AM
When I was first trying to get the guitar to hold it's tuning with 10's I thought about adding another spring. But then I realized that it wasn't necessary because there's this little black piece that goes over the three springs and I would've had to take them off. Plus adding more springs will just make the trem feel tighter. So instead I just cut a little piece off of the springs and re-attached them and that did the trick. You can cut them with a strong enough wire cutter without a problem. Just make sure that you don't cut off but a little bit at a time AND that you can find extra strings in case you mess it up.
post #10 of 17 (permalink) Old 08-10-2005, 12:21 PM Thread Starter
Reviews: 5
Can you buy stronger springs?
because my springs are over stretched and very loose.
Also I heard that the silver coloured ones are stronger.
Cheers on the tips
post #11 of 17 (permalink) Old 08-11-2005, 09:30 AM
You can buy any kind of springs you want. Any guitar shop that does repair work should have some on hand.
post #12 of 17 (permalink) Old 08-15-2005, 10:25 AM Thread Starter
Reviews: 5
The place where I live Ireland has none.
They offered me these midget ones that were for a childs toy or something.
Anyone know online I can get some.
Anyone heard of all parts.
Wildchild
post #13 of 17 (permalink) Old 08-15-2005, 11:05 AM
http://www.stewmac.com/
They sell all kinds of parts.
post #14 of 17 (permalink) Old 08-22-2005, 06:59 AM
Talking Re: Problem with RG 370 DX
hey man i put a set of 10's on my rg370 and all i had to do was screw in the metal bit on the back of the guitar where the springs are in further, make sure you loosen the strings before yuo do it put them like a step down or something and then tighten the back, it should work no problem, hey where in ireland you from?
jem_fanatic is offline
post #15 of 17 (permalink) Old 08-30-2005, 08:32 PM Thread Starter
Reviews: 5
problem fixed
I am running 4 springs now and I am not using 10s I am using custom gauge 9-46
thanks for the help guys
you really helped me.
i am from the deep south, scum hole of the south, Waterford boy, waaaaaaahhhh boy, degly dush dush techno techno, land of the nackers, I'll bust ya if ya don't give us a go of your shoes boy.
Sorry but I hate the scum in this town.
Where are you from??
guitar shop , trem springs
problem with PM's? evolvedmb Forum Announcements and Member Help 0 03-17-2008 06:30 AM
problem with EMG ZW set kral Pickups & wiring 1 09-02-2004 05:22 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
Any problem setting up for BEADGB? - Any problem setting up Pudreaux Ibanez JEM, UV, JS & Other Signature Models 2 06-28-2001 02:56 PM
