Question for 7620 owners! - Jemsite
post #1 of 8 (permalink) Old 07-29-2007, 10:50 PM Thread Starter
Hi guys,
I recently got a 7620 (grey - very cool) and am very happy with it, its a fantastic guitar. However, Im finding that the high E string is slipping off the fretboard alot when I play. I compared the distance of the high E to the edge of the fret to my Schecter Hellraiser 7 string, and the 7620 is MUCH closer to the edge of the fret, so that if you move a small amount the string just slides off. Is this normal/correct for this model? Has anyone else experienced this with a 7620? Ive owned quite a few guitars and have never had this problem before.
Cheers
jthompso is offline
post #2 of 8 (permalink) Old 07-30-2007, 12:25 AM
Re: Question for 7620 owners!
I had this happen with one of mine. It ended up being that the nut was a little bit out of alignment, as well as, the neck angle being a little bit off. Once I fixed that, all was good.
IBZ Addict is offline
post #3 of 8 (permalink) Old 07-30-2007, 03:22 AM
sounds abnormal. it could be as simple as what IBZ^ mentioned, but it'd be worth getting it checked out.
wildealien is offline
post #4 of 8 (permalink) Old 07-30-2007, 12:32 PM
jim777's Avatar
Is it like that the whole length of the string or does it get more pronounced in the upper registers?
jim777 is offline
post #5 of 8 (permalink) Old 07-30-2007, 02:29 PM
/\ I suspect Jim's on the right track here.
I've got a UV with the nut slightly out of alignment, maybe a mm off center towards the low B side. However, it's the only Floyd-equipped guitar I've ever seen where this was an issue (it's also something like 16 years old, lol) so I suspect Jim's right, that it's not the nut but rather it's your neck that's slightly out of alignment.
If so, it's an easy enough fix, though it'll probably make you rather nervous to do - simply, you need to slightly loosen up the four bolts holding the neck to the body, and then push on the side of the neck to allow it to "shift" back into alignment in the neck pocket, and then tighten them back up. Problem solved. :agreed:
I've always loved the 7620GN's, partly because it is a subtle, attractive finish, and partly because I vastly prefer the Powder Cosmo hardware to plain black - I've been meaning to grab one of those and have an alder replacement body done up for years.
Drew is offline
post #6 of 8 (permalink) Old 07-31-2007, 02:03 AM Thread Starter
thanks for the responses guys! I read some of the "setup" instructions on this site and may have found the problem/s. The nut isnt centered properly, so Ill re-adjust that. One other thing I noticed is that if you look at the positioning of the bridge in the bridge cavity, there is more of a gap on the low E side than the high E side, is this normal or should it be equal?
jthompso is offline
post #7 of 8 (permalink) Old 07-31-2007, 02:06 AM Thread Starter
How do you know when the neck has shifted back into alignment? Do you need to use much force? Sounds scary!!
jthompso is offline
post #8 of 8 (permalink) Old 08-06-2007, 07:58 AM Thread Starter
It definately is closer to the edge of the fret higher up the fret board?
jthompso is offline
cosmo hardware , equipped guitar , fret board , neck angle
Question for JSX Combo Owners Xerack Gear, Equipment, Recording & Off Topic 0 02-06-2007 08:54 PM
JEM7vwh fretboard question to other JEM owners marlb5150 Ibanez JEM, UV, JS & Other Signature Models 2 02-11-2006 03:51 PM
Question for Owners of SZ Series Guitars (a little favor) stratoskier All Other Guitars (including Prestige) 3 02-02-2004 07:18 PM
Question for Soldano SLO owners Dan D Mahnn Gear, Equipment, Recording & Off Topic 0 06-21-2003 01:17 PM
Question for LNG/similar owners, etc. steve Ibanez JEM, UV, JS & Other Signature Models 2 05-28-2003 12:03 AM
