Question about the edge pro bridge on higher end Ibanez - Jemsite
post #1 of 4 (permalink) Old 11-19-2005, 05:20 AM Thread Starter
Hi folks. I am aware (by reading other posts) that alot of you guys prefer the edge pro bridge on the Ibanez prestige guitars versus the edge pro 2 on RGT's and standard RGs.
What makes the Edge pro so much better then the edge pro 2? Ive not played a edge pro (but have a pro2), however visually it seems there is no difference between two as best as I can tell. Is it just a "it feels better" type of things?
I am debating buying another Ibanez and trying to find out what will best suit my needs. Thanks for your help.
elpingua is offline
post #2 of 4 (permalink) Old 11-19-2005, 06:04 AM
Re: Question about the edge pro bridge on higher end Ibanez
Well there are a couple of main reasons why the edge pro is better:
- The Edge pro is made at the Gotoh factoy in japan
- Its made of much higher quality HARDENED steels instead of the cheaper, softer steel used in the PRO 2
- It has the sound-metal chip which promotes longer string life, more accurate intonation and increased sustain
- Has the trem bar as used in the Edge/Lo-Pro edge which is tighter and smoother
- And although i havnt tried one yet (My RG1527 hasn't arrived yet) i would assume it would have superior feel
The Edge Pro is far superior to the Edge Pro 2 and thats why its used on the UVs, JEMs, JSs and prestiges and i cant wait to try mine out.
ibanez.shredder is offline
post #3 of 4 (permalink) Old 11-19-2005, 06:15 AM
what he said (mostly).
the edge pro II generally has a much stiffer feel than the edge pro.
visually, they are very similar, bar the inserts that the edge pro II lacks.
damo7v is offline
post #4 of 4 (permalink) Old 11-19-2005, 09:20 AM
The Edge Pro II ain't that bad as it is an upgrade of the old TRS trems, but after having to setup both Edge Pro and Edge Pro II trems, I gotta say that the construction on the Edge Pro II feels a bit cheap.
If you're a serious abuser of the trem, you will want either an Edge/Lo-Pro/Edge Pro or an OFR, if you're an occasional abuser of the trem, the edge pro II may be fine. In the end it all boils down to how much you use it and how abusive you are with it. But I would personally go with an Edge Pro over an Edge Pro II.
buddroyce is offline
edge pro bridge , prestige guitar , prestige guitars , pro edge , trs trems
Original Edge - One saddle higher than the others... jemboyee Tech: Setup, Repairs and Mods 3 07-23-2012 08:35 PM
Edge Studs higher on one side then the other faekildare All Other Guitars (including Prestige) 5 02-17-2011 12:57 AM
Quick question - can i fit the edge bridge on a new JS1000? lonewolf Ibanez JEM, UV, JS & Other Signature Models 2 12-04-2008 11:09 AM
Bridge Knife Edge Question tt0511 Ibanez JEM, UV, JS & Other Signature Models 5 05-04-2007 11:24 PM
