a question about edge-pro on rg2570 - Jemsite
post #1 of 12 (permalink) Old 12-25-2005, 10:34 AM Thread Starter
i want my tremolo arm not to fall down when i stop holding it in my hand..Steve vai uses edge-pro too and his tremolo arm doesn't fall down,it can stay parallel to the strings without holding...How can i make my tremolo arm like that?
**i have 2 white teflon washers on my tremolo arm...
canneerr is offline
post #2 of 12 (permalink) Old 12-25-2005, 11:43 AM
Re: a question about edge-pro on rg2570
My trem arm doesn't as you say 'fall down' on my Strat's trem. This is because it's a screw-in trem arm and I can tighten it. The Edge Pro's arm is a pop-in style, so I have no experience with them. Vai doesn't use Edge Pros, but Lo Pros.
King Knall is offline
post #3 of 12 (permalink) Old 12-25-2005, 04:00 PM Thread Starter
it's edge-pro,same as my guitar's bridge...I looked samdaymusic,you can see it's picture on this site,it's an edge-pro with a different colour
canneerr is offline
post #4 of 12 (permalink) Old 12-25-2005, 05:15 PM
New washers will stiffen it up considerably
Bahamut is offline
post #5 of 12 (permalink) Old 12-26-2005, 12:34 AM
You are mistaken about Vai using Edge Pros. Yes, they put the Edge Pro on the production JEMs and on the guitars that he holds for photoshoots, but live he still uses his older JEMs with Lo Pro Edges on them. Either way, I'm sure there's a way to make it so that your arm stays in one spot. I remember reading something about using fingernail polish on the trem bar to thicken it somewhat so that it would stay still after use...
lyconxero is offline
post #6 of 12 (permalink) Old 12-26-2005, 12:38 AM
Steve used several EP equipped VSBL's live for the euro leg of UZ tour.
Rich is offline
post #7 of 12 (permalink) Old 12-27-2005, 02:02 PM Thread Starter
the washers are new and i tried using fingernail polish but it doesn't work.Is there anyway to make it?
canneerr is offline
post #8 of 12 (permalink) Old 12-27-2005, 04:49 PM
could i ask a question on edge pro too? since someone create a thread before me? if i cut off the ball end and put it in an edge pro, will it still have the same stablity? since edge pro doesnt require string to be cut off . . . actually i prefer the ball end over the headstock, im pretty lazy u know ;d
Jing is offline
post #9 of 12 (permalink) Old 12-27-2005, 06:01 PM
Maybe it could be the arm-holder spring at the bottom of the arm-socket?
Magnus Olssen, who posts here as Ibanez-Mag, has a fantastic site which details tremelo maintenance:
http://www.magnusolsson.com/index2.htm
You'll find details in the Guitar Setup section of the menu on the left side of the page. I've found this to be the only site detailing such maintenance that's on a par with Rich's maintenance section.
Hope this helps!
Awakened Sleeper is offline
post #10 of 12 (permalink) Old 12-28-2005, 07:38 AM
Question Re: a question about edge-pro on rg2570
hi, iīm new here, english is not my mother language, so excuse me if iīll do some kind of "language-mistake" , and i also have a question on this topic:
i always take out the arm when iīm not playing, īcause i left it for 2 days in the case, and i noticed that the bridge was a little "pushed-down", because the arm touch the case... (i hope it didnīt made anything bad to the springs, i think not).
anyway, because the arm is always getting in and out in the bridge, the washers may suffer a little, so itīs not too stiff as it was a month ago (the guitar is new). i also noticed that there is a ind of a "gap", itīs a question of not even a milimeter, but the arm is not 1000000% stick to the bridge (i hope you get my idea, itīs like you "feel" the arm with a very very little space inside the hole, that lets it 0,000001 milimeter gap) . is it normal due to the use?
thank you!
wonderman is offline
post #11 of 12 (permalink) Old 12-30-2005, 12:40 PM Thread Starter
i solve the problem...I never thought that the washers can lose condition in 25-30 days,i changed the washers and now the tremolo arm has very good condition...
How long do the washers keep in condition for somebody playing 3 hours a day(using the floydrose a lot)?
canneerr is offline
post #12 of 12 (permalink) Old 01-02-2006, 07:23 PM
With daily use, the nylon bushings can wear down in a matter of weeks. But they are easy to buy so replace them as need be.
Paul Secondino is offline
edge pros , pro edge , steve vai , trem arm , tremolo arm
How can I check whether my RG2570 body takes an Edge Pro or Edge Zero trem? JayCartay All Other Guitars (including Prestige) 6 11-18-2012 06:23 PM
Edge/OFR question. I need help! Guitarzan_Josh Tech: Setup, Repairs and Mods 10 01-06-2011 03:50 PM
Edge III Question... Shreddy Krueger Tech: Setup, Repairs and Mods 0 02-04-2007 07:35 PM
question about Edge xklusivly4u Ibanez JEM, UV, JS & Other Signature Models 4 11-15-2005 12:29 PM
an EDGE question... Juanozzy Ibanez JEM, UV, JS & Other Signature Models 4 10-09-2005 01:55 PM
