Question about setting up intonation with Edge tool... - Jemsite
post #1 of 4 (permalink) Old 10-24-2005, 03:18 PM Thread Starter
Hi guys, I had posted a month or so back about how I aquired a late 80's RG550 and how I was going to fix it up. Well I installed all new pickups, set up the floyd yadda yadda.
The guitar sounds great, but after tuning, certain chords are out of tune in different places. Is it safe to say that the intonation needs to be adjusted, as well as the neck relief??
If so, I'm ready to do the intonation, but ran into a problem. I aquired an Edge intonation tool from Rich to use on the guitar. I'm a bit confused though, here's why: When I install the tool, it presses down on the allen bolt under the fine tuners (bolt that opens and closes saddles), making the note sharp. Is it intentionally done like this?? I ask, because I'm not sure if the intonation will be accurate if the note is a bit sharp from this. I am tuned to standard D if that matters at all.
Lastly, is it better to do the intonation before the neck relief?? Or vice versa??
Thanks.
-Joe
mityjoeyoungxnj is offline
post #2 of 4 (permalink) Old 10-24-2005, 03:22 PM
Re: Question about setting up intonation with Edge tool...
Intonation is done last with everything else already set up, and then tweak the trem angle afterwards as it will change when the intonation is adjusted if there's much adjustment required.
Tune the string after the tool is on, then adjust.
Rich is offline
post #3 of 4 (permalink) Old 10-28-2005, 01:15 PM Thread Starter
Anybody else have any tips?? I'm just not quite getting this tool. If i install it, it pushes down on the allen bolt, making the string sharp. If I install it and tune the string, won't it still be sharp.
-Joe
post #4 of 4 (permalink) Old 10-31-2005, 09:04 AM
No. When it makes the string go sharp, just tune it back down to pitch. Intonate. When you take the tool off, retune the string to pitch.
whatshisname is offline
edge intonation tool , intonation tool , neck relief
Edge Intonation Tool! BlanK Tech: Setup, Repairs and Mods 11 08-06-2012 09:31 PM
Edge Intonation Tool... chaos731 Tech: Setup, Repairs and Mods 9 05-19-2008 05:56 PM
Edge Intonation Tool waylay00 Tech: Setup, Repairs and Mods 16 11-04-2007 01:02 AM
WTB: Edge Intonation tool GLG421 Classified Ads: Guitars and Gear 6 05-05-2005 08:58 PM
Lo Pro Edge intonation tool... Bluestreak Tech: Setup, Repairs and Mods 4 02-01-2005 03:26 PM
