Question about the SV5470's tremolo system - Jemsite
post #1 of 13 (permalink) Old 11-05-2008, 06:02 PM Thread Starter
Quick question about about the SV5470's tremolo system, and please consider the following:
1) I hate floating trems
2) Have little experience/understanding about them
That being said I have a Fender Strat with a "standard" old-style trem. My guitar shop basically made the trem "non-floating" by having the trem rest on the body. What this means is that I can bend notes flat (dive bomb) but I can NOT pull up on the trem to make notes sharp...and I can rest my hand on the bridge without notes going sharp.
Does the SV5470 or any of the SV guitars allow for this type of configuration?
Thanks!
- Tony
TonyG73 is offline
post #2 of 13 (permalink) Old 11-05-2008, 08:01 PM
Re: Question about the SV5470's tremolo system
There's a "bolt" in the trem cavity you can screw against the trem block to prevent pull up. You can add as much spring tension to it as you want to keep bent double stops in tune. Or, you can use it free floating. All depends on how it's setup.
Rich is offline
post #3 of 13 (permalink) Old 11-06-2008, 12:46 AM
MFB
The way it comes set up from the factory I believe actually prevents "fluttering" which as you may know and/or guess from the name involves pulling up, so right away you can immediately start playing
MFB is offline
post #4 of 13 (permalink) Old 11-06-2008, 12:58 AM
I should clarify that the pull up range is basically vibrato only. About a half step.
Rich is offline
post #5 of 13 (permalink) Old 11-06-2008, 12:18 PM
GAZ
Question Re: Question about the SV5470's tremolo system
How can you hate something you don't understand or have any experience of ?!?!?
GAZ is offline
post #6 of 13 (permalink) Old 11-06-2008, 02:11 PM Thread Starter
Sorry, should have clarified...I hate the guitars that I've played that have floating trems. What I should have said is that I don't own any guitars with floating trems and the ones that I've played are far less stable than a fixed bridge and a pain in the ass to set up.
So to clarify, my limited experience with Floyd Rose trem systems while not extensive, leads me to conclude that they are not for me.
TonyG73 is offline
post #7 of 13 (permalink) Old 11-06-2008, 02:12 PM Thread Starter
Rich do you perform this type of setup on the Ibanez's you sell?
TonyG73 is offline
post #8 of 13 (permalink) Old 11-06-2008, 02:38 PM
I do any level of setup you choose
http://ibanezrules.com/new/setup_levels.htm
Rich is offline
post #9 of 13 (permalink) Old 11-06-2008, 03:02 PM
jb4674's Avatar
Reviews: 18
I wish you could do setups on gear not bought from you. I would love to have my 1000 setup by you.
Jimmy
jb4674 is offline
post #10 of 13 (permalink) Old 11-06-2008, 03:13 PM
Maybe next year you can be the lucky job I take on
Rich is offline
post #11 of 13 (permalink) Old 11-11-2012, 08:08 PM
I keep the spring tension on my SV rather stiff. Resting my palm on it doesn't affect it at all. It takes quite a bit of force to dive or pull up. Much like my strats. I don't use the trem for drastic dives, I developed a "bend-technique" for that. I use the trem for just that..."tremolo".
The trem on the SV was the reason I chose it over the S series.
dvsoul is offline
post #12 of 13 (permalink) Old 11-11-2012, 08:18 PM
CosmicDebris's Avatar
4yr old thread dude and the OP hasn't been around in 3yrish.
CosmicDebris is offline
post #13 of 13 (permalink) Old 11-11-2012, 09:21 PM
Damn, looks like I got a case of the Monday's, on a Sunday night. Lol
dvsoul is offline
sv5470
tremolo system from rg 770 steini All Other Guitars (including Prestige) 8 09-12-2008 04:47 AM
tremolo system for my RG320? bjamin86 All Other Guitars (including Prestige) 2 05-21-2006 11:59 PM
D TUNA EVH will it work on original Edge tremolo system mattpj All Other Guitars (including Prestige) 2 01-21-2004 01:35 PM
