Question regarding PRS guitars... - Jemsite
post #1 of 9 (permalink) Old 04-29-2012, 05:35 PM Thread Starter
Hello!
I'm a big fan of PRS guitars and if you can find a picture on the web of a PRS guitar I've not seen, then I'd be suprised!
Anyway, I've been thinking about this for a while now and I can't seem to find any answer. On pretty much every PRS guitar I've seen, the heel looks kind of... big. Very big.
Just an example of what I'm talking about (the thick "bottom" of the neck):
To me it looks pretty strange and I'm quite sure that it would be a way more comfortable guitar to play if the heel was smaller. I can't figure out any reason to why this should be a good thing either. If you ask me I'd say that the thickness of the heel is because you'll need something to attach the body to, but then why is the thick part hanging out so far from the body? Not sure if that was correct English but nevermind, you get my point!
So well, why is this? Anyone got any ideas? I'm really curious to see if there is a logical answer...
JonatanOTG is offline
post #2 of 9 (permalink) Old 04-29-2012, 06:03 PM
Re: Question regarding PRS guitars...
wasn't always like that . that was changed around 92 i believe. Paul decided it would sound better and make the joint more stable. And even though its fairly large i never had any issues with the upper registers
dragsternj is offline
post #3 of 9 (permalink) Old 04-29-2012, 06:18 PM
Yes, most probably they had tone in mind
mertay is offline
post #4 of 9 (permalink) Old 04-29-2012, 06:25 PM
Reviews: 12
^^ like Drag and Mertray have already stated, it was probably for more sustain and stability.
Never really noticed the heel on mine honestly... but then again, I have huge, spidery fingers.
GroovyTubes is offline
post #5 of 9 (permalink) Old 04-30-2012, 07:53 AM Thread Starter
So it's like more wood equals better tone then? Well, that seems kind of logical (I guess... ).
post #6 of 9 (permalink) Old 04-30-2012, 09:12 AM
More like lessening the vibration on the neck since they can't use much material there.
mertay is offline
post #7 of 9 (permalink) Old 04-30-2012, 06:19 PM
The bigger heel lends strength and stability to the neck. If you've ever played a set neck mahogany guitar with a small heel try this -- with the guitar laying down, strum the strings. Now lift the guitar up by the neck near the headstock while the strings are still ringing (you just have to lift slightly, the body end can remain on the floor/in the case/wherever the guitar is laying). You should hear the pitch drop slightly because there is flexion at the neck joint. I had a Dean flying v and a Hamer that did this.
replica is offline
post #8 of 9 (permalink) Old 05-01-2012, 02:17 AM
It was used to remove deadspots on the neck. I had a PRS SE with a massive heel. It didn't affect playability whatsoever. Infact, it was quite comfortable.
BlanK is offline
post #9 of 9 (permalink) Old 05-01-2012, 05:55 AM Thread Starter
Thanks for the input. The example with a small heeled-guitar makes sense to me, although I can't try it at the moment.
I'll keep those words in mind next time I get to try a PRS out (unfortunately they are not the most ordinary guitars around in my part of the world... )!
heel , heel neck , neck , prs
Question about 2009 RGA Series Guitars Miggy~ All Other Guitars (including Prestige) 1 06-12-2009 07:31 AM
A question about Steves guitars Sam b Ibanez JEM, UV, JS & Other Signature Models 5 10-28-2005 11:28 PM
3 new guitars (plus, a pickup question) Clydefrog All Other Guitars (including Prestige) 7 08-05-2004 06:19 AM
A Question About LGM Guitars Southpaw's Curse Vendors, Auction & Reseller Talk 19 07-19-2004 02:49 PM
Question about recent NAMM guitars. ScottM All Other Guitars (including Prestige) 2 02-01-2002 09:29 AM
