Question for S2170 owners - Jemsite
post #1 of 2 (permalink) Old 09-13-2010, 02:11 AM Thread Starter
I have an S2170FW and the published neck specs I found (wikia) say it has a "Wizard II Prestige" neck which is supposed to measure 48mm width Nut and 65mm width at last fret HOWEVER mine measures 43mm Nut and 58mm at last fret.
I was wondering if any of you out there with S2170's could do a quick neck width measurement at nut and last fret and let me know what you get?
I am assuming that the specs I found are wrong and that it is either not a Wizard II Prestige neck or the specs published for that neck are wrong???
beacher is offline
post #2 of 2 (permalink) Old 09-13-2010, 06:01 AM
Re: Question for S2170 owners
48mm and 65mm would a 7 string neck. The width isn't really that different between a Wizard, Wizard 2, Super Wizard etc, its the thickness and more importantly the profile, which the dimensions can't tell you, you have to feel the neck to get it.
You probably do have the Wizard II Prestige.
littlephil is offline
s2170
Prestige owners, a question. littlephil All Other Guitars (including Prestige) 1 03-18-2010 03:37 AM
UV owners question djpharoah Ibanez JEM, UV, JS & Other Signature Models 3 01-10-2008 01:59 AM
Question for 7620 owners! jthompso All Other Guitars (including Prestige) 7 08-06-2007 07:58 AM
A question for all you JEM owners Spider-Skot Ibanez JEM, UV, JS & Other Signature Models 22 05-03-2006 10:59 AM
S2170 finish question. 70Seven All Other Guitars (including Prestige) 5 03-10-2006 02:28 PM
