Radius project - Jemsite
post #1 of 4 (permalink) Old 04-26-2005, 10:32 AM Thread Starter
Radius project
I just got a mega deal: Radius in fountain blue for 189 with Dimarzio X2N and Fred. The X2N was in the neck :-/ (he routed it for a humbucker) and the wiring was botched so i have to re wire the whole thing. Should be a hell of a player though.There are three coil tap switches and two push pull pots (go figure). So i am going to put two 500k pots in with a three way and a .22 capacitor. It is my first wiring job and should be pretty simple. I just need to know how to ground. I know you soder to the trem plate but where does the other end soder to? It also came with a schaller collar arm already installed. :-) Will post pics when it is all set up/cleaned up.
Kontalonis is offline
post #2 of 4 (permalink) Old 04-26-2005, 09:02 PM
Flobanez's Avatar
Re: Radius project
Awesome. Show some pics and congratulations!
Flobanez is offline
post #3 of 4 (permalink) Old 04-26-2005, 09:07 PM
Re: Radius project
*quick mental calculation..* $189= 95 :O !!!!!
You can't even get a second hand squier affinity strat over hear for that little!
2 Dimarzios, and a cool body to work on! *drool*
I guess what they say is true: The USA is the land of oppourtunity!
I demand pics!!
Globbits is offline
post #4 of 4 (permalink) Old 04-27-2005, 02:53 AM
Re: Radius project
you have to solder the other end to the bottom of a pot, usually. enjoy your luck, man!
nuno is offline
coil tap , trem plate
540R Radius maple board project stratoskier All Other Guitars (including Prestige) 8 03-05-2014 10:19 AM
Bridge radius vs fretboard radius F242 All Other Guitars (including Prestige) 4 11-21-2009 10:17 AM
New project completed! Radius 440R-HH inside! jazzedout All Other Guitars (including Prestige) 12 08-01-2009 06:19 AM
Saddle Radius on Edge Not Matched to Fingerboard Radius? Zerimas Pickups & wiring 5 08-12-2007 05:03 PM
JEM7DBK nut/bridge radius differs from neck radius ?!?! jemoctave Ibanez JEM, UV, JS & Other Signature Models 5 01-30-2005 12:21 AM
