Reclaimation Project or Cut my losses? - Jemsite
post #1 of 8 (permalink) Old 10-19-2009, 08:22 PM Thread Starter
Reviews: 59
Unhappy Reclaimation Project or Cut my losses?
So, I'm working on setting up my 2000 LTD M-100 today and one of my tremolo anchor screws pulls out of the hole. It's stripped out the anchor hole and will need to be filled and re-drilled. My last woodworking attempt resulted in needing a new dining room table, so I don't consider myself up for a DIY. The guitar is just under 10 years old and I've made some mods to it like adding an Edge trem, Paf Joe and Fred pickups as well as push-pull pots wired to split the coils and give the hi-pass filter. Those would probably sell for 2/3rds what I paid for it back in high school....
My question is, do you think it's worth paying to get the hole filled and re-drilled or should I just break the guitar down to parts and move on, or thirdly? I can't remember the last time I played this guitar so I kind of feel like I might as well break it down and sell it off for some extra cash rather than pay to fix it up. That said, if I should only expect it to cost me $50 or so, I might as well get the work done on it and keep it. My limit to pay would be $100 but I would start weighing my options at $75 since I don't play the guitar that often, it's been a backup since I got my JS1200. Your thoughts are greatly appreciated on the subject...
smooth55 is offline
post #2 of 8 (permalink) Old 10-19-2009, 08:54 PM
Re: Reclaimation Project or Cut my losses?
It's really not that hard to do that quick fix. Just measure a million times, and cut once.
nato101010 is offline
post #3 of 8 (permalink) Old 10-19-2009, 09:40 PM
fill the hole with super glue and toothpicks and move along.
LuredMaul is offline
post #4 of 8 (permalink) Old 10-20-2009, 10:20 AM Thread Starter
Reviews: 59
super glue and tooth picks? I'm willing to give it a go, anything I should be aware of for the MacGyver special?
smooth55 is offline
post #5 of 8 (permalink) Old 10-20-2009, 11:42 AM
jb4674's Avatar
Reviews: 18
Don't use super glue and tooth picks, that's the lazy way to fix it. If you're going to fix it, do it right and do it once. Super glue will be needed as part of the solution but not as the solution.
Remove the anchor, clean up the hole, buy some wood filler, fill up the hole, let it sit for a day or so and then redrill the hole using a hand drill. Once the hole is drilled and you've determined that the anchor will go in, brush some super glue on to the hole with a miniature brush, tap the achor in and let it sit for a day or so. Once it dries, that anchor won't move at all.
Jimmy
jb4674 is offline
post #6 of 8 (permalink) Old 10-20-2009, 12:19 PM Thread Starter
Reviews: 59
The only problem I can foresee with that is that I don't want to fix the anchor screw in there in case I decide to change string gauges down the road or need to make an adjustment to level the bridge. Is the superglue part of that really necessary? Can't I just fill it with wood-filler and drill and then put the screw in leaving it able to be adjusted?
smooth55 is offline
post #7 of 8 (permalink) Old 10-20-2009, 12:57 PM
Superglue the anchor into the body, not the adjustment screw into the anchor.
Defy704 is offline
post #8 of 8 (permalink) Old 10-20-2009, 08:51 PM
Superglue and toothpicks will work perfectly. it's cheap easy and simple.
It will be solid if you tap enough toothpicks in the hole.
m-100
Project RG Xavier 7 All Other Guitars (including Prestige) 2 09-28-2006 03:18 PM
Ever wondered how much your project will cost ?? Post project costs here ! Jaden Players & Bands, Music & Sounds, Tours & Jams, Lessons & Theory! 12 08-29-2006 07:48 PM
recording project isn't looking good - recording project isn shredmaster Ibanez JEM, UV, JS & Other Signature Models 8 11-12-2001 10:17 AM
Project Axes - project guitars Bradly Smith All Other Guitars (including Prestige) 4 10-09-2001 06:50 PM
Project Guitar Ideas - Opinions wanted on project jem7vwh Tech: Setup, Repairs and Mods 11 12-19-2000 11:27 PM
