Recommend me a single coil for my HSH configuration! - Jemsite
post #1 of 11 (permalink) Old 05-19-2008, 10:33 PM Thread Starter
Talking Recommend me a single coil for my HSH configuration!
I finally found love with my RG1570 after putting a Tone Zone in the bridge and a Breed in the neck. But After trying endless pickups in the middle position, (chopper, air norton s, blue velvet) I can't seem to find one I like.
So I've decided to put it back to 5 way switching and give it a Jem wiring setup.
But what single coil should I use with the tone zone and breed? The blue velvet was honestly too trebly. I want something warm and smooth that will sound great when combined with the splitted humbuckers.
Whada ya think?
jbandy10 is offline
post #2 of 11 (permalink) Old 05-19-2008, 11:50 PM
Re: Recommend me a single coil for my HSH configuration!
The HS-2 in split mode is great..kinda close to the Jem single coil..but I liked the Jem single the best. From my experiences..I found the HS-2 to be a bit noisy.
mozfan98 is offline
post #3 of 11 (permalink) Old 05-20-2008, 05:41 AM
VV heavy blues or pro track for reducing as much treble.
rich
rty13ibz98 is offline
post #4 of 11 (permalink) Old 05-20-2008, 08:32 AM
Reviews: 4
Try the HS-2, as stated above, but in full hum-cancelling mode. Split it only for positions 2 and 4.
Man, it is sweet!
Crazy_Guitar is offline
post #5 of 11 (permalink) Old 05-20-2008, 08:57 AM
gitarrero's Avatar
I was asking myself the same question not long ago when I needed a middle pickup to complete a set of Steve's Special (bridge) and FRED (neck) pickups. I just went for a Chopper in the middle position and it works out simply great. You get chunky rhythm sounds, a strong clear tone and crispy in-between sounds in selector positions 2 and 4 when the humbuckers are in split-mode.
gitarrero is offline
post #6 of 11 (permalink) Old 05-21-2008, 09:50 AM
Just got an Area '58 for the mid position on my 1570. Pairing it with a PAFpro and Evo2, so not sure how it'll sound, but I LOVE the clarity/vintage sound of the Area '58! You could also try the Area '61... I think it's a bit fuller and a bit bassier, IMO.
XcitR is offline
post #7 of 11 (permalink) Old 05-21-2008, 10:41 AM
Reviews: 4
I have that combination, only with the HS-2 in the middle.
Since in positions 2 and 4 the middle is used in single-coil mode, it makes use of the fantastic vintage sound (just as used by Eric Johnson).
Is the Area '58 a stack single coil?
post #8 of 11 (permalink) Old 05-23-2008, 01:31 AM
Dimarzio lists it as a "humbucking single coil." It's a 4wire with single pole pieces (staggered heights), so I don't think it's a stacked coil. They also say that they've virtually eliminated the single coil hum.
I'll have to give a review when I get it installed, but it may be a week or so. The guitar it's going in is getting clear coated right now, and it's decided to present a few headaches in its final stages Ain't that the way it always goes???
How do you like the PAFpro and Evo2 combo?
XcitR is offline
post #9 of 11 (permalink) Old 05-23-2008, 09:48 AM
I have an Area61 that I just bought for the middle pickup. I love the sound of the vintage Strat pickups, there's a mellow-smooth quality to them. I also considered the Area58, and in retrospect, maybe I should have bought that one.
ken_r152 is offline
post #10 of 11 (permalink) Old 05-23-2008, 10:07 AM
Dimarzio Cruiser is and will always be my favorite single coil pickup. I tried it on a whim because Andy Timmons used it, and if its good enough for him...
Turns out its absolutely fantastic. Give it a shot . I also have an Area 61 for the middle pickup of my SSH custom axe and I love it as well for that vintage-y sound.
shreddersymphony is offline
post #11 of 11 (permalink) Old 05-23-2008, 11:16 PM
I just bought a NOS VS-1 (DP-108 oldie but goodie) that I'm trowing in my 1570 when it arrives- I'll post how it works out. It iwll be paired with PAF Pros (ala USA Custom setup from early 90s).
jallen is offline
air norton , andy timmons , clear coat , coil mode , coil pickup , eric johnson , paf pro , paf pros , strat pickups , tone zone , vintage strat
Sustainer - Replacing Dummy Coil with Single Coil? F.P.R.O. Pickups & wiring 7 09-12-2007 03:33 AM
Best middle single coil in HSH P/up configuration? Smitty Gear, Equipment, Recording & Off Topic 5 08-14-2007 06:30 PM
Jem single coil? rickcard71 Ibanez JEM, UV, JS & Other Signature Models 30 03-10-2006 02:56 AM
Single coil sized pickup similar to an Air Norton? Kindred_Spirits Pickups & wiring 4 05-10-2005 11:43 AM
Replacement Single Coil for BFP? Dunadan Pickups & wiring 6 07-05-2004 12:22 AM
