Removing Nail Polish - Jemsite
post #1 of 24 (permalink) Old 05-06-2010, 05:54 PM Thread Starter
Reviews: 4
Question Removing Nail Polish
Well, I am part-time guitar tech and I'm fixing up this old Ibanez 7 string of my buddy's(when I finish, I'm going to post a thread on the history of this guitar, it's ridiculous, but for now...). There's white nail polish on the Black finish that some A-Hole slapped on there trying to make it look like pin-stripping, it looks anything but. He wants it removed, but I don't want to damage the actual underlying finish. It's on the headstock as well, yes he tried to pinstripe the whole guitar!!! Has anyone removed nail polish before and did it have any affects on the finish and if not, what did you use? If anyone can shed some light on this it would be greatly appreciated...
LordGrendel is offline
post #2 of 24 (permalink) Old 05-06-2010, 06:01 PM
Reviews: 15
Re: Removing Nail Polish
Acetone for removing nail polish... BUT... I've no idea if it'll play nice with the polyester clear on the finish. Can you try it inside the trem cavity or somewhere else hidden?
MarkE is offline
post #3 of 24 (permalink) Old 05-06-2010, 06:41 PM
Reviews: 120
Acetone will probably mess up the finish, after all it is used to clean paint off things. You might have to carefully sand it with a fine sandpaper.
LonePhantom is offline
post #4 of 24 (permalink) Old 05-06-2010, 08:50 PM Thread Starter
Reviews: 4
I was a fiberglass fabricator for years, yeah acetone is not an option. Fine sandpaper, ehh...That's too risky...Thanks for the ideas though...This thread is still open...Anyone else?
post #5 of 24 (permalink) Old 05-06-2010, 08:59 PM
Reviews: 12
not sure how it works on the clear finish but i just tried one of these to remove thick nail polish on a switch tip... polish dissolved real fast.
reguv760 is offline
post #6 of 24 (permalink) Old 05-07-2010, 12:02 PM Thread Starter
Reviews: 4
Anyone else?
post #7 of 24 (permalink) Old 05-07-2010, 04:59 PM Thread Starter
Reviews: 4
I might look into experimenting with this, does anyone disagree?
post #8 of 24 (permalink) Old 05-07-2010, 05:12 PM
As advised above try applying inside the trem cavity and give it a couple of days just to be sure there's no lingering effects
Ibateur is offline
post #9 of 24 (permalink) Old 05-07-2010, 06:07 PM
i colored the vine neck on a 555 before with bright green nail varnish.i only coloured the leaves on the vine at frets 3-5-7-9 ect ect.i swapped the guitar for a amp few years later,but before i swapped it i removed the varnish with nail varnish remover.the green varnish was painted on at least 5 years before i swapped it,anyways the varnish remover worked a treat.you couldnt tell that id painted it with varnish.just ordinary nail varnish remover,you can buy this anywhere
rob777vdy is offline
post #10 of 24 (permalink) Old 05-07-2010, 07:54 PM Thread Starter
Reviews: 4
It's a RG7421, there is no trem cavity...Maybe the neck cavity or the output jack cavity although that's really small, but I'll check it all out and give a test run and post my findings. Thank you to everyone who gave advice, and if there's anyone else who has any ideas, please don't hesitate to offer...
post #11 of 24 (permalink) Old 05-07-2010, 09:32 PM
This sounds weird but try some WD-40. Let it soak a bit, then use your fingernail. The WD40 should penetrate the polish and losen it while leaving no oil residue. WD40 works to remove all kinds of adhesives, it may make the polish pliable enough to remove.
good luck!
kwik69 is offline
post #12 of 24 (permalink) Old 05-09-2010, 04:37 AM Thread Starter
Reviews: 4
Sounds like an interesting idea. I shall try that first...
post #13 of 24 (permalink) Old 05-09-2010, 01:15 PM
Mineral spirits perhaps?
C.Thep is offline
post #14 of 24 (permalink) Old 05-09-2010, 07:05 PM Thread Starter
Reviews: 4
Hmmm, mineral spirits, that's an idea as well...I'm going to try some of these and whomever is right wins the prize!!
post #15 of 24 (permalink) Old 05-09-2010, 07:22 PM
Nail polish remover is lacquer thinner, which will probably do nothing to the poly finish on the body, though I've never tried removing nail polish from a body either.
Rich is offline
nail polish
Fixing chips with nail polish - Can it be done? superhairycamel Tech: Setup, Repairs and Mods 6 07-19-2006 06:47 AM
Tightening the trem bar with nail polish...anyone do this? nukem2k5 Tech: Setup, Repairs and Mods 7 06-06-2004 03:21 PM
LO TRS II nail polish prsdimarzio Tech: Setup, Repairs and Mods 11 12-12-2003 04:05 AM
Help me nail this song in two weeks toneseeker Gear, Equipment, Recording & Off Topic 1 11-11-2002 10:23 AM
gold finish - nail polish, an idea? swiggy Ibanez JEM, UV, JS & Other Signature Models 1 03-07-2001 07:17 PM
