Replace Edge Zero ZPS3 to Lo pro Edge - Jemsite
 2Likes
  • 1 Post By kfssdude
  • 1 Post By nzSkitzo
post #1 of 13 (permalink) Old 03-30-2012, 10:11 AM Thread Starter
Hi,
I bought an Ibanez J Custom RG8570Z at january 2012.
That guitar has an amazing look, but I donīt like the sound.
The sharp chords sustain (E, B, G) is short and weak.
My brother has an old Ibanez RG370 and it has best leading tone that my J custom. (More output and bright sustain on sharp chords).
At the begining , I think it would be an wood feature (J custom is mahogany top flamed) , but now I think it would be a tremolo feature.
I will replace the bridge pickup for evo 2.
I like the edge zero ZPS3 trem (I remove the zero point system) , but the sustain block on the trem is very thin. I think it is the problem.
It is possible replace this tremolo for lo por edge ?
If not, it is possible replace the sustain block on edge zero ?
If yes, anyone recommends any product ?
Thanks ..
raflemos is offline
post #2 of 13 (permalink) Old 03-30-2012, 10:35 AM
Re: Replace Edge Zero ZPS3 to Lo pro Edge
Seems its about both a pick-up and trem. situation you have.
Pick-up: that rg 370 probably has a cheap highout-put pickup in it whats bright and compressed, probably sounds bad when spilt or clean sounds but yeah an evo 2 should do the trick if you need something more wild.
Trem: Been a lo-pro user for years and recently examined the new zps feature, if you want more sustain and brighter sound put it back. Its about how much the trem wiggles when you play the strings, the less you get more sustain but the movement of trem is either limited or stiff.
You can also block the trem to dive-only but I wouldn't do that for such a guitar. Personally I think the zps is a very good solution.
mertay is offline
post #3 of 13 (permalink) Old 03-30-2012, 01:21 PM
FloydUpgrades.com sells solid brass upgrade tone blocks for most trems. I know hes got them for most of the edge models but I'm not sure about the zp3. You'd need to check his site.
These are great for improving sustain and resonance, but are larger than stock and will compromise some of your trem range of motion. Generally you can't pull up as much with an aftermarket block. If you dont do a lot of up-trem they're great though! Still a full floating setup so you can flutter & dive-bomb just fine.
One thing though. Your ZP trem cavity is significantly larger than a standard edge/Lo-pro cavity so I don't know if that will change the dynamics of replacing the trem with one of these older more traditional styles. I would think it wouldn't be a big deal, but I don't know for sure. Prob just have to use fewer springs as they will be stretched farther, or get longer spring claw screws so that you can adjust it farther out. But you also wanna double check the studs - never had a zp trem so I have no idea if they are the same spacing as an edge Lo-Pro. If not, I highly recommend leaving it alone. You don't wanna do a stud change with a flame top axe. I would consult a pro guitar tech before attempting it yourself just to be sure. It may be no big deal, but it definitely is not a standard direct swap type deal.
As for the pups the EVO2 is great. My favorite bridge pup these days - I have them in 2 Jems and an RG. Very versatile pup good for many different tones, and very responsive to guitar volume knob changes. At full vol it still screams! Lower output than the original EVO but in my opinion smoother and more balanced.
Good luck man!
Hoseki likes this.
kfssdude is offline
post #4 of 13 (permalink) Old 03-30-2012, 02:57 PM
I sent and email last month asking about blocks for the EZ. They said that it's still on their list but didn't give a time frame. I'm thinking about designing one and having a local machine shop make a couple for me out of titanium. I'm not in a rush so maybe Floydupgrades will have one by then.
johnnyninja is offline
post #5 of 13 (permalink) Old 03-30-2012, 03:02 PM
Ti is an excellent tone block for a mahogany body but is awfully bright/trebly for an alder or basswood body in my experience. I'm having a local machine shop make a few custom Tungsten blocks to fit Edge & Lo-pro trems for my Jems & will let you know how they sound when done. Based on my research they should tonally balance Alder and basswood perfectly!
kfssdude is offline
post #6 of 13 (permalink) Old 04-02-2012, 02:35 PM
wow....I haven't had any issues with any of the 3 J Customs that I have with the Edge Zero trem's. Mine sustain great!!! I have my Jem FP2 with Edge Pro to compare with. Perhaps something is going on with the neck and how it was seated in the pocket?
PBGas is offline
post #7 of 13 (permalink) Old 04-02-2012, 03:23 PM
I don't think my 1570 sustains badly. I just figure that a block would help. Other than a couple, most of my guitars that I've owned have sustained about the same, acoustically. I'm not in an environment where I can crank an amp so I really can't experience "sustain" that just sings and keeps going. I got back into playing after a 20 year layoff and just play at home. At this point, I'm not even sure what qualifies as good vs average sustain.
post #8 of 13 (permalink) Old 04-02-2012, 08:09 PM Thread Starter
Hi,
thanks for answer.
There isn't any neck problem on guitar.
The sustain of thin chords is normal, but just a bit lower than an basswood/alder guitar.
When you play the two guitar without plug it on amp, you realize the thin chords on rg8570z stop to sound before rg370, or maybe the rg8570 concentrate your sustain on bass chords.
It make me think it would be a material trem/body problem/feature...
I saw a lot of videos on youtube about rg8570z and if you are "exigent", you figure out on that videos a subtle lower sustain on mahogany guitar on high/thin chords.
When you play, you need to compensate your strengh to extend the sustain (dynamics ?).
I like a lot the guitar and the trem, but I was expecting the best for the product category.
I give up to replace the trem, but I am waiting a evo 2 buyed on ebay arrived to replace the pickups.
Maybe it would be a mahogany feature
raflemos is offline
post #9 of 13 (permalink) Old 04-03-2012, 10:02 AM
I have an EVO2 on one of my J Customs. It's sounds nice. It may help with some of the output issues.
PBGas is offline
post #10 of 13 (permalink) Old 04-03-2012, 12:03 PM
RGTFanatic's Avatar
For me, there's NO WAY I would attempt retro fitting a Lo-Pro into ANY EZ equipped JC. You'd be cutting into a perfectly fine instrument on a "guess" that it will make the difference your hoping for. It could just as easily go the other way. Then your screwed.....
I would make sure you have an absolutely top notch setup done on it done by a true luthier. You could do a complete electronics upgrade and pups at the same time.
Why do I say take it to a luthier?? Because this is a pristine JC were talking about....not a mass produced RGwhatever. The guitar you have can give you what you want with the hardware it has on it currently.........let a pro have at it for awhile, then be amazed at what you get back.
RGTFanatic is offline
post #11 of 13 (permalink) Old 04-13-2012, 03:39 PM
I did this to my RG8570Z a few months back and now have my ultimate guitar = ) will post pics later.
nzSkitzo is offline
post #12 of 13 (permalink) Old 04-16-2012, 08:44 AM Thread Starter
hi nzSkitzo ,
Thanks for information.
The replace make the guitar sound better ?
You need any work on guitar to replace the trem ?
You change the pickups too ?
Please, tell what you change on that guitar and if it make the guitar sound better ...
raflemos is offline
post #13 of 13 (permalink) Old 06-14-2012, 10:39 PM
Sorry for the late reply but check this link
http://www.jemsite.com/forums/f21/ed...ge-121098.html
I wouldnt say the guitar sounds any different, I did it because the Original edge is more comfortable for me and I hated the fine tuners on the Edge Zero. I havn't changed the pickups.
Hoseki likes this.
nzSkitzo is offline
edge zero , lo pro edge , rg8570z , sustain
edge pro v/s edge zero II with zps3? dreamtallica All Other Guitars (including Prestige) 1 06-07-2011 10:32 PM
Can I replace Jackson JT580 with Edge Pro or Edge III Tremolo? Izzyprad Tech: Setup, Repairs and Mods 11 05-04-2010 08:57 AM
Replace Edge-ZERO with Original-EDGE? SilverEra Tech: Setup, Repairs and Mods 7 06-25-2009 03:36 AM
Can you replace an edge trem with a LoPro Edge? - Is it poss Cycovision Tech: Setup, Repairs and Mods 7 05-16-2009 12:22 AM
Replace Edge Pro With Edge/ Lo-pro Edge Trem Vaistarr Tech: Setup, Repairs and Mods 28 04-01-2008 12:18 PM
