Restoring my old first Ibanez - Jemsite
post #1 of 13 (permalink) Old 05-06-2011, 11:35 PM Thread Starter
My first Ibanez brought back from the dead. Now with pics!
My first Ibanez, an EX170 I bought new in 1992, brought back from the dead. At a distance it didn't look too bad, but it was damaged in a move where the neck was ripped off, and I had butchered it trying to keep the trem in tune. Many youth-inspired missteps had taken their toll as well. Lower horn was missing a chunk of wood, truss rod nut busted, strap button ripped out, trem cavity filled with Liquid Nails (don't ask), pickups removed, etc. Just lots of bad stuff. I swear, Eddie Van Halen has led to the ruining of many a good guitar! So it found it's way into a box for years. I always loved that flat neck, so now at 38 I'm brining it back.
I set out to do this on a budget, so I reused what I could. The tuners being the thing that need upgrading the most eventually. I made my own hardtail bridge, using the old saddles so I could cover the trem hole and some screw holes I made years ago. Humbuckers are " Hot OEM Extras" from Guitar Fetish, with the single coil being an actual GFS. The neck and middle coil tap. No tone control.
So, from this (I scratched the "EX" off the headstock years ago)
In process:
To this:
DH
Displaced Hokie is offline
post #2 of 13 (permalink) Old 05-07-2011, 12:43 AM
RGTFanatic's Avatar
Re: Restoring my old first Ibanez
Wow Man!!! nicest EX ever!!! what pups did you use???
RGTFanatic is offline
post #3 of 13 (permalink) Old 05-07-2011, 01:20 AM Thread Starter
First thanks for the complement!
The middle pickup is a Guitar Fetish GFS "Little Killer" in the "modern" 10K resistance. A VERY nice sounding pickup, bucking or tapped.
http://www.guitarfetish.com/Lil-Kill...ble_p_463.html
The humbuckers are from the clearance section at Guitar Fetish...$29 for the pair and they sound pretty good for the price.
http://www.guitarfetish.com/WHITE-Ho...ups_p_854.html
The bridge pickup is pretty hot, with kind of a Dimebag tone which is OK with me. The neck is a little muddy, but not bad. It's nice tapped. One standout position I've found is the neck/mid split with the coils tapped.
I could add a push/pull pot to split the bridge pickup, but don't think I'd ever use it.
Thanks again!
post #4 of 13 (permalink) Old 05-07-2011, 03:41 AM
Reviews: 11
nice!!!! how does the bridge sound and sustain? because i cant tell if its made of metal or plastic
D.M.RG7620 is offline
post #5 of 13 (permalink) Old 05-07-2011, 10:58 AM Thread Starter
It's a complement that you can't tell what it's made of! It's steel, and the sustain is great and far better than it used to be. I considered adding even more mass to it, but this is heavy as it is. The bridge plate is made from 3/16" high-strength steel, and was a bear to drill through as a result. It was free from my neighbor that sells steel, so I can't complain. I welded it up myself...
The base plate with mounting holes drilled, string holes drilled and chamfered:
Fabbed up, ready to weld:
Welded, ground, hanging ready for paint:
Oddly I could not find anywhere on the interwebs where anyone had built their own bridge before. I wanted ideas. Luckily mine has worked great. I may need to get some shorter saddle height screws as they are sticking up pretty good.
post #6 of 13 (permalink) Old 05-07-2011, 02:56 PM
thats one of the coolest restorations ive seen on here,might i ask the process you used to remove the old paint?i have a guitar im wanting to remove the paint from and im not sure which method i want to go with.but as i stated before, awesome job
Boombatty is offline
post #7 of 13 (permalink) Old 05-07-2011, 06:37 PM Thread Starter
Thanks, glad you like it! I used a heat gun and scraper to remove 90% of it. Far faster than trying to sand it off. After that I used a rotary polisher/sander with a 220-grit pad to clean it up. Both cheapie Harbor Freight tools. The polisher comes in handy for your final polishing step, or for your car. In fact, I bought the polisher to clean up my wife's truck, and since it came with the sandpaper pad, it actually spurred me to work on this as I thought "hey, I bet I could use that on my old guitar"!
Heat gun:
http://www.harborfreight.com/1500-wa...112-96289.html
Polisher/sander:
http://www.harborfreight.com/7-inch-...her-66615.html
Thanks again!
post #8 of 13 (permalink) Old 05-09-2011, 03:01 PM
dude u should sell those bridges, it looks sweet! i would totally buy one hahaha
rg_man 1993 is offline
post #9 of 13 (permalink) Old 05-09-2011, 06:42 PM
Reviews: 120
Very cool bridge, and great work!
LonePhantom is offline
post #10 of 13 (permalink) Old 05-09-2011, 07:37 PM
Reviews: 11
edit : i should read the whole thread lmao.
linuxpenguin is offline
post #11 of 13 (permalink) Old 05-12-2011, 11:05 PM
That's awesome. Really nice job on that bridge. You could probably grind those intonation screws down a bit if you can't find shorter ones. I probably wouldn't bother unless your palms annoyed with them though.
lerxst6 is offline
post #12 of 13 (permalink) Old 05-12-2011, 11:49 PM
Way more than I could do by myself lol...but very cool restore!
PrestigeWorldwide is offline
post #13 of 13 (permalink) Old 05-13-2011, 08:13 AM
Reviews: 19
Great job!! Love the burst, palm muting must be a bitch!
*Thinks about my own EX...
Shockme.au is offline
ex series ex170
Restoring my rg550 Gerard All Other Guitars (including Prestige) 9 05-26-2010 10:28 AM
Restoring edge bebisatch All Other Guitars (including Prestige) 18 04-26-2010 05:08 PM
restoring old rg550 project jemplayer24 Tech: Setup, Repairs and Mods 2 04-18-2005 10:48 AM
Restoring colour? Amadeus Ibanez JEM, UV, JS & Other Signature Models 10 03-02-2003 09:56 AM
Restoring USA Custom Graphic TAorama Tech: Setup, Repairs and Mods 1 07-23-2002 01:22 AM
