rg 2550 problem - Jemsite
post #1 of 27 (permalink) Old 12-15-2007, 11:09 PM Thread Starter
rg 2550 problem
just got my guitar after waiting 2 months.got it set up at my music store.brought it home and put the tremolo arm on and low and behold it bangs off the volume nob when its spun in and outta place.then i reset my action which brought the tremolo arm closer to the body and of course its still doin it.its like the volume knob is too close or the angle of the trem bar isn't right.either way it sucks.
any suggestions on how to remedy this problem?
i have two icemen and an rg350mdx and never had this problem before
chooch is offline
post #2 of 27 (permalink) Old 12-16-2007, 12:02 AM
CosmicDebris's Avatar
Re: rg 2550 problem
Can you post any pics?
CosmicDebris is offline
post #3 of 27 (permalink) Old 12-16-2007, 07:38 AM
Re: rg 2550 problem
Ah, this is a famous RG2550 gotcha... I have this problem myself, and have heard of countless other 2550 users who suffer the same problem.
Personally I've just learned to live with it by moving the arm round slightly so it doesn't hit the volume pot, but you could raise the action a little and see if that helps.
Quite annoying!
'87
Shredder87 is offline
post #4 of 27 (permalink) Old 12-16-2007, 09:53 AM
Re: rg 2550 problem
The neck needs a shim.
Your music store should be able to do that.
Vinco is offline
post #5 of 27 (permalink) Old 12-16-2007, 03:58 PM
Re: rg 2550 problem
Maybe the trem angle is incorrect? You have set the trem up to be flat (when compared to the body), right?
nord is offline
post #6 of 27 (permalink) Old 12-16-2007, 04:56 PM
Dino's Avatar
Re: rg 2550 problem
Dino is offline
post #7 of 27 (permalink) Old 12-20-2007, 04:07 PM
Re: rg 2550 problem
Hey,
If the bar is just clipping the pot, just lower the pot a bit. There should be a little screw on the knob, turn that a little and it should drop.
Hope you can sort it out 2550 brother!
Rekuss is offline
post #8 of 27 (permalink) Old 12-20-2007, 05:01 PM
Dee
Re: rg 2550 problem
It can also clip the 5-way if it's in the middle position.
Tighten trem spring tension to pull the arm back slightly, or shim the neck.
Dee is offline
post #9 of 27 (permalink) Old 12-20-2007, 06:23 PM
Re: rg 2550 problem
its really nothing to do with the neck at all, did you read the first post?
postofficebuddy is offline
post #10 of 27 (permalink) Old 12-20-2007, 07:25 PM
Dee
Re: rg 2550 problem
Yes it is. If the neck is raised out of the body a little bit (shimmed) then you can raise the bridge and the bar will not hit the vol knob. Problem solved.
I had the same thing happening on my RG 20th. I increased the spring tension to angle the bridge back a little, and that cured the problem. I don't like shims, but that's just one way of solving the issue he's having.
Dee is offline
post #11 of 27 (permalink) Old 12-21-2007, 07:25 AM
Reviews: 16
Re: rg 2550 problem
Yea, I think everyone has this problem with the 2550s. I had the same thing. The quickest and easiest solution is to loosen the set screw on the side of the volume knob and then lower the volume knob slightly by pushing down on it. Then tighten the set screw again and your problem will be solved.
I don't know why this is particular to the 2550. I haven't seen it on another one yet.
courtney2018 is offline
post #12 of 27 (permalink) Old 12-21-2007, 07:02 PM
Re: rg 2550 problem
That may be the quickest and easiest thing to ''resolve'' the issue, but that doesn't mean it's the correct way. I was having the same issue with my 2550, read the post about the trem angle and remember reading about it on Ibanezrules.com. I went back to Ibanezrulze.com and studied this article...
http://www.ibanezrules.com/tech/setup/angle.htm
I fixed this very issue by Rich's suggestions (Thanks Rich!) and got everything lined up with no neck shim, no swapping out the volume knob or lowering it...now this thing plays and sounds great!
I probably have about 1/4'' clearance now!
One thing to note though....you may have to raise the action slightly to get back the same feel as you did before. I didn't like the thought of raising the action either but when I studied the old trem angle and thought about the lower action with the lifted trem, leveling the trem flat put the strings much closer to the fret board (makes sense when you think about it)...once I thought about it and raised the action, I was a happy camper!
All I can say is, line everything up like Rich says...and if you still have issues, THEN start thinking about neck shims and any other changes.
billyboy is offline
post #13 of 27 (permalink) Old 12-22-2007, 08:26 AM
Reviews: 16
Re: rg 2550 problem
Sounds like your problem was the trem angle. Mine was perfect, so my only real problem was the trem arm hitting the volume knob.
post #14 of 27 (permalink) Old 12-22-2007, 12:35 PM
Dino's Avatar
Re: rg 2550 problem
I would still like to see some pics of this happening. Somebody please post.
Dino is offline
post #15 of 27 (permalink) Old 12-22-2007, 05:28 PM Thread Starter
Re: rg 2550 problem
hey thanks for all your responses.i finally posted some pics.let me know if they're not helpful and i'll take more.
if ya look closely you'll see the trem bar resting right atop the volume knob.
the trem is level.
action is low.i've lowered it since i brought it home but was still touching after initial set up.
it was set up without trem bar on at the shop
<a href="http://s105.photobucket.com/albums/m207/doctorfoster/?action=view&current=100_0540.jpg" target="_blank"><img src="http://i105.photobucket.com/albums/m207/doctorfoster/100_0540.jpg" border="0" alt="Photobucket"></a>
<a href="http://s105.photobucket.com/albums/m207/doctorfoster/?action=view&current=100_0541.jpg" target="_blank"><img src="http://i105.photobucket.com/albums/m207/doctorfoster/100_0541.jpg" border="0" alt="Photobucket"></a>
<a href="http://s105.photobucket.com/albums/m207/doctorfoster/?action=view&current=100_0539.jpg" target="_blank"><img src="http://i105.photobucket.com/albums/m207/doctorfoster/100_0539.jpg" border="0" alt="Photobucket"></a>
chooch is offline
edge trem , equipped guitar , fret board , music store , neck shim , trem arm , tremolo arm
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
RG Prestige 1620X buzzing problem ANT All Other Guitars (including Prestige) 1 04-17-2006 03:26 AM
RG tone pot problem Shredder87 All Other Guitars (including Prestige) 3 04-16-2006 06:02 AM
Eek! RG neck problem - help! Fink Floyd Tech: Setup, Repairs and Mods 2 08-01-2003 10:17 AM
RG 620X Wiring Problem kirk Tech: Setup, Repairs and Mods 43 08-23-2002 04:51 PM
