rg 350 questions - Jemsite
post #1 of 2 (permalink) Old 03-22-2012, 06:00 PM Thread Starter
rg 350 questions
Hello,
I just pick up an RG 350ex. I got it off ebay ($157 with the case) and had a few questions.
1. I believe it is a 2010 model and may have a wizard 3 neck but I'm not sure? I did notice that the screws that hold the locking nut to the neck are NOT visible through the back of the neck....Usually one can see the two screws that hold the locking nut on an RG... Does this mean it is a wizard 3 neck and not a wizard 2?
2. I need to adjust the action..It is a bit high for my taste. Do I need to loosen the strings before i turn down the studs? I have looked for an answer to this and have gotten conflicting reports about damaging the knife edges on the trem.
Thanks for in advance for the help
Greg
zeebo271 is offline
post #2 of 2 (permalink) Old 03-22-2012, 06:22 PM
Reviews: 4
Re: rg 350 questions
Hey, I can't properly answer all of your questions, but the 2010 wizard II is actually the same spec as the wizard III, they just renamed it in 2011 to prevent confusion.
About adjusting your action, the Edge III has cheaper metal than high end trems, obviously, so if I were you, I would not loosen my strings, instead I would undo the two outer springs for the trem - that will relieve a lot of tension, and will make it so you will not need to retune when you put the springs back on! It works like a charm for me every time!
Good luck and welcome to jemsite!
fwd0120 is offline
rg 350 tremolo , wizard 3
Few questions about my RG Swat Man All Other Guitars (including Prestige) 5 05-16-2010 05:15 AM
a few questions... Revaku All Other Guitars (including Prestige) 2 11-12-2008 11:44 AM
RG questions.... ultimecia All Other Guitars (including Prestige) 6 12-29-2007 06:41 AM
2 questions Playloud78 Gear, Equipment, Recording & Off Topic 22 12-22-2007 12:06 PM
Ibanez JS Questions!!! - Please answer these questions I hav Ibaman Ibanez JEM, UV, JS & Other Signature Models 6 09-08-2001 02:10 PM
