RG 350dx, neck problems. - Jemsite
post #1 of 5 (permalink) Old 08-13-2012, 09:18 AM Thread Starter
Hey guys, i have an Ibanez RG350dx (blocked trem) and the action of the strings is too high, when i tried to lower the bridge i had freezes when i bend the 22-24th frets. The notes also goes out of tune as i progress in the neck but i tried to fix the harmonics thing (12th frets harmonics are similar to the fretted note)
Any advices?
fataston is offline
post #2 of 5 (permalink) Old 08-13-2012, 06:22 PM
Re: RG 350dx, neck problems.
Any advices?
Hi mate, i have exact same axe .If they are set up right and looked after they should play sweet.
What do you mean by blocked trem?,mine has an edge 3.
You can adjust trem hight for action but while doin this make sure you slacken the strings as it can damage the knife edges, but also you need to balance your string tension with the springs in the rear as they work against each other and the trem should be level with the body.Not being pulled up or down.
Your truss rod may need adjusting too as this can cause fret buzz and give you low action up near head stock and high action at higher frets.
You get all these things working together and it should be good.
Mines a 2009,never abused and looked after and i only did all this on mine 2 weeks ago as i changed gauge of strings,polished the frets and oiled up the rose wood and she plays like a dream.
Is the trem in good condition? hope this helps you,...cheers
bodsy is offline
post #3 of 5 (permalink) Old 08-13-2012, 10:10 PM Thread Starter
Thanks a lot dude! I blocked the trem by using an ingenious mechanism(a piece of wood), i'll try this manipulation and keep in touch!
Really appreciate your help!
fataston is offline
post #4 of 5 (permalink) Old 08-13-2012, 10:39 PM
may need to shim your neck possibly.. or adjust the truss rod but if your notes are going out of tune as you go up, you need to intonate your guitar by moving the saddles on the bridge towards or away from the nut. youtube should have some tutorials or there is probably a good one on here if you search
GUITARMAGEDDON is offline
post #5 of 5 (permalink) Old 08-14-2012, 12:33 AM
Reviews: 98
Use this:
AlaskaBat is offline
ibanez , problem , rg350
FT: RG470 w/350DX Neck woodsofpenn Classified Ads: Guitars and Gear 1 08-09-2011 03:33 PM
The new RG 350dx with a all maple neck Roadstar All Other Guitars (including Prestige) 25 01-28-2007 08:49 PM
TRADE RG 350DX for Edge Pro Bridge or prestige neck!!! hachimako Classified Ads: Guitars and Gear 4 07-07-2006 02:36 PM
Neck problems phil27 Tech: Setup, Repairs and Mods 6 08-29-2005 10:02 PM
neck problems, help! Kyo7442 Tech: Setup, Repairs and Mods 3 01-06-2003 03:24 AM
