Rg-7620 Problem - Jemsite
post #1 of 5 (permalink) Old 11-24-2003, 08:34 PM Thread Starter
Rg-7620 Problem
I recently bought a used Rg7620("F" serial, Edge trem) that was well taken care of.
I am however having some confusing trouble.
It seems to focus on the pickups; which are directly mounted to the body and ( I believe) are Dimarizo's put in by the ibanez factory ( correct me if I'm wrong).
It has a 5 way switch for the two humbuckers and I am familier with the various configurations.
The problem seems to lie when useing any dist pedal or Dist channel on my amp(s). Clean, the sound very clear, not to bass or trebal heavy, which is ok.
But pile on some dist, and they are too "plucky" for lack of a better term. Almost too much midrange or like they are being phase switched or tapped. Either in bridge or neck setting this condition exists. The only way around it it to turn the tone knob on the guitar DOWN or OFF, thereby adding what shoud be a lot of bass or using some really odd EQ settings on my amp. This seems to help clear it up, but I'm pretty sure it should not be this way.
I did research the wiring diagram and all seems to be wired correctly.
Also, I tapped the slugs with a allen wrench while plugged in with the 5 way on "bridge "setting. I found that; both coils on the bridge were on AND the bottom coil of the neck was on! BUT , it was not as appearent sounding as the bridge coils. Seeing that the wiring is all in place( I compared it four times over 2 days) I have no idea why this guitar acts so strangly.
It's very hard to get a good dist sound ( or at least the sound I want) out of this guitar in this condition so if anybody has any suggestions, I would appreciate.
I belive the sound i am looking for is attainable with these stock equipmnet.
sorry for the long-winded-ness..
Sephiroth000 is offline
post #2 of 5 (permalink) Old 11-24-2003, 10:37 PM
Hmm. The only thing I would suggest is that something is wrong somewhere along the line and if you're confident with a soldering iron and wiring diagram, get the diagram off the Ibanez website and rewire it from scratch. It's not that difficult if you have a steady hand.
Petie is offline
post #3 of 5 (permalink) Old 11-25-2003, 07:31 PM
Check to see if the 5-way has been replaced with a non-original switch, and thereby, incorrectly wired (even if it /looks/ correctly wired).
The terminal assignments and internal normalling of the 5-way in an RG7x20 (and similar instruments with two humbuckers) are not 'normal' as compared to an average switch; it's a 'Megaswitch'-like device which creates coil configurations not possible with an ordinary 5-way.
steve is offline
post #4 of 5 (permalink) Old 11-25-2003, 08:08 PM
Petie is offline
post #5 of 5 (permalink) Old 11-26-2003, 07:19 PM Thread Starter
Something is definatly up.. I'm gonna look into replace ment pickups anyways and have it rewired for me.. I guess I have no other choice..
allen wrench , edge trem , wiring diagram
FS/FT 98' RG-7620 uberthrall Classified Ads: Guitars and Gear 0 09-17-2012 01:46 AM
NGD 7620 satchbooger All Other Guitars (including Prestige) 6 12-20-2008 02:36 PM
How much would I be able to buy a 7620 for? Xexxhoshi All Other Guitars (including Prestige) 3 07-01-2006 06:16 AM
Wierd Lo-Pro Edge 7 problem... big problem! Jupiter Tech: Setup, Repairs and Mods 5 06-11-2003 01:43 PM
UV777BK trem problem - I think it is a problem (shrug) Scoff X Tech: Setup, Repairs and Mods 5 09-21-2001 12:59 AM
