RG 920 Premium custom build - Jemsite
post #1 of 2 (permalink) Old 02-10-2013, 12:31 PM Thread Starter
I just bought a RG920 Premium body and now have the chance to buy a S5EX1 24 fret neck. I believe the neck is a Wizard 2 (not sure). The neck has a 58mm heel, that is for sure. Will this neck be compatible. Should I just keep searching for a Wizard neck.
Octivarium is offline
post #2 of 2 (permalink) Old 02-10-2013, 12:36 PM
Re: RG 920 Premium custom build
It will fit, and intonate, but depending on the bolt pattern (and the accuracy thereof) you may need to dowel and re-drill the mounting holes.
I am unaware of if the Premium mounting holes correspond with the normal indonesian pattern, or the Korean/Japanese pattern.
It used to be that indonesian instruments used a different layout than japanese and korean, but since Premium is so different to normal indonesian runs, it may have either bolt pattern. I haven't seen confirmation either way, but I'm sure someone here has.
GuitarBizarre is offline
New custom build 7 . Zoot All Other Guitars (including Prestige) 29 02-22-2013 12:25 PM
Custom Uni build . Zoot Ibanez JEM, UV, JS & Other Signature Models 29 06-13-2012 01:59 AM
RG Custom build IrishIbby All Other Guitars (including Prestige) 21 12-05-2011 01:48 AM
Custom Build GuitarGuru All Other Guitars (including Prestige) 7 01-13-2011 12:12 AM
Jem DNA Custom Build vanbuxton Ibanez JEM, UV, JS & Other Signature Models 4 07-09-2009 11:51 PM
