RG to jem conversion question - Jemsite
post #1 of 21 (permalink) Old 12-27-2005, 02:34 AM Thread Starter
My dad bought me an RG conversion on **** for x-mas. It is already swirled. The lion's claw is kinda messed up and there is no jem input. It also needs a clear coat. I am wondering if there is anything I can do to fix the input or lions claw without having to refinish the body. I am also wondering if anyone knows of a good tutorial on clear coating.
magkid45 is offline
post #2 of 21 (permalink) Old 12-27-2005, 03:03 AM
Re: RG to jem conversion question
First things first, visit www.projectguitar.com, there is a tutorial on JEM conversions there.
That's the best first step I can recommend, and welcome to the forums
Ibateur is offline
post #3 of 21 (permalink) Old 12-27-2005, 04:43 AM Thread Starter
Thanks, I have looked there. I don't think there is much I can do with the lions claw. I didn't see much about the clear coat.
magkid45 is offline
post #4 of 21 (permalink) Old 12-27-2005, 06:31 AM
Sorry about that.
There's a tutorial to painting a guitar at reranch.com. The part on clearcoating is included, of course. I followed this when I painted my strat resinator plywood guitar (before selling it off for parts), albeit with different type of paint.
Ibateur is offline
post #5 of 21 (permalink) Old 12-27-2005, 12:05 PM
How's the swirl when you got it? If it's superb, then you might wanna hesitate on repainting it.
You know how swirls work!
aj_foes is offline
post #6 of 21 (permalink) Old 12-27-2005, 11:47 PM Thread Starter
Its pretty cool. It just needs a clear coat. Thanks for the info on painting that helps quite a bit. I would just like a more accurate lion's claw. I am wondering if there is a way to re route it and then hand paint the lions claw, or paint it a solid color w/o it looking too bad.
magkid45 is offline
post #7 of 21 (permalink) Old 12-28-2005, 03:08 AM
How bad does it look?
You could reroute it (with all the associated risks), and then hand paint it using one of the colors of the swirl, so it won't look too bad. If it doesn't look too bad, with the hardware on it, then just clear coat it.
Ibateur is offline
post #8 of 21 (permalink) Old 12-28-2005, 12:55 PM Thread Starter
http://viewmorepics.myspace.com/inde...B3397C66555983
there is a link to the pic. Its just the bottom of the claw. Looks like he inserted the wood block and just routed the block and not any of the body.
magkid45 is offline
post #9 of 21 (permalink) Old 12-28-2005, 01:48 PM
bluealien's Avatar
Well looking at it, when you put in a EDGE trem, it will cover most of the Lion Claw, I would just suggest clear coating it and put it together, its not ever going to be perfect, even the Monkey Grip looks to big.. its a RG converson.. well good luck..
bluealien is offline
post #10 of 21 (permalink) Old 12-28-2005, 02:05 PM
That's a very nice swirly thing. The swirl in my opinion hides the defect. If, when you install the trem, the issue affects playability, then take it to a proper wood guy.
Otherwise, I would agree with bluealien, just clearcoat it, install the hardware, and off you go.
As an aside the trem route looks TRS-sy.
Ibateur is offline
post #11 of 21 (permalink) Old 12-28-2005, 02:49 PM Thread Starter
will an edge fit then?? I ordered a lo pro
magkid45 is offline
post #12 of 21 (permalink) Old 12-28-2005, 03:27 PM
bluealien's Avatar
Nice catch "Ibateur", it does look like is routed for a TRS, so "magkid45", it looks like you will have to get a TRS, a Lo Pro will not fit. The body must be from a 470 or a lower model number.
post #13 of 21 (permalink) Old 12-28-2005, 06:15 PM Thread Starter
oof, looks like I got screwed. They said it was a high end RG body so I assumed edge. woops.
magkid45 is offline
post #14 of 21 (permalink) Old 12-28-2005, 07:01 PM Thread Starter
can it be routed to fit the edge lo pro? Will a LO-TRS fit? What is the difference between the two?
magkid45 is offline
post #15 of 21 (permalink) Old 12-29-2005, 02:30 AM
First things first, you have to confirm the route. Compare it against the multitudes of pictures on the web of an Edge route and see if it is indeed different.
I believe it can be routed, but that's gonna damage the swirl and will not be the best looking thing on the planet. I think the project guitar site has a conversion tutorial.
Other option would be an OFR trem which wouldn't need additional routing, but will leave some gaps. Don't get a Lo-TRS yet as it isn't the best performing trem we know.
Does the neck pocket show any model number? I guess it would be under the primer coat.
Ibateur is offline
clear coat , edge trem , floyd rose , jem conversion , monkey grip , paf pro
UV Conversion? paulramon1992 Ibanez JEM, UV, JS & Other Signature Models 28 03-25-2012 06:04 AM
noob question: wiz I to wiz II neck conversion? soliloquy All Other Guitars (including Prestige) 4 02-26-2010 02:04 AM
470 Jem Conversion courtney2018 Tech: Setup, Repairs and Mods 13 01-27-2009 05:16 AM
ZR conversion DavyH Tech: Setup, Repairs and Mods 2 12-11-2007 02:24 AM
nut to locking nut conversion question RapIsNotMusic Tech: Setup, Repairs and Mods 16 02-14-2005 04:27 PM
