Rg1200 Trem Re-String Woes - Jemsite
post #1 of 2 (permalink) Old 02-05-2006, 06:15 PM Thread Starter
Hey guys this is my first post over here. I'm having a bit of trouble trying to restring the D string on my RG1200. I believe its a Lo-Pro trem, I'm not sure exactly what model it is. Anyways, whenever I break the D string I unlock the saddle and try to pull out the string and it does not come out not matter how much I unscrew the saddle. On all the other strings they come out without a problem and I can install the string without a problem. Sorry for the noobish question, this is my first locking trem guitar. Any help is appreciated.
ibz1200 is offline
post #2 of 2 (permalink) Old 02-05-2006, 06:47 PM
Re: Rg1200 Trem Re-String Woes
Simply push the small block that locks down your string with a screw driver or something similar. This is quite common actually. If you're still getting this problem pull out the small block entirely and see if there's any rust building up on it. If there is, clean it off, otherwise if it's clean and it just doesn't quite fit into the saddle properly, just file one side down a little.
(DO make sure you inserted the block properly with the small circle indentation facing towards the screw before you start to do anything with the block)
buddroyce is offline
trem guitar
New Guitar Day - RG1200 metalgod72 All Other Guitars (including Prestige) 2 01-03-2012 11:02 AM
LOOKING FOR RG1200.... jl2556 Classified Ads: Guitars and Gear 0 11-12-2010 10:05 PM
Trem post set screws - I found them and they fixed my woes! bachle7 Archived Topics and Common Questions 46 05-31-2009 07:37 PM
Trem post set screws - I found them and they fixed my woes! bachle7 Tech: Setup, Repairs and Mods 40 07-02-2001 07:12 PM
