RG1527 and APEX2 sound issues - Jemsite
post #1 of 7 (permalink) Old 03-15-2011, 10:17 PM Thread Starter
HoP
OK, so ive been playing a RG1527 for like 6 years, I swapped the pups out for a PAF7 in bridge, and a Blaze7 in neck. I decided to purchase a APEX2 for a backup guitar, and I was baffled that... these guitars sound completely different.. ive got the same pups in bridge position and just cannot get the same sound. (and yes they are wired correctly) so my question is... could it be the pots are that different that it would effect the sound? my 1527 has more sustain and it more "metal" and smooth then my APEX2, which sounds great.. but not alot of sustain... and i guess just way to "korny" for me lol. but its just too different for me.. I need my APEX2 to sound like my 1527.. any ideas?? im trying to figure out how these guitars with same PUPS can sound so different.. only thing I can think of is pots.. but I didnt think pots had a huge influence on sound.
thanks for ANY help!
-Tyler
HoP is offline
post #2 of 7 (permalink) Old 03-15-2011, 10:47 PM
Reviews: 21
Re: RG1527 and APEX2 sound issues
The RG1527 is made of basswood and has a trem.
The Apex2 is made of mahogany and is fixed bridge.
I'm not sure these guitars will sound the same with the same pickups. You might need to go with a D Activator? I'm not sure. Typically one goes for different wood deliberately to get a different sound.
Also, I think logically the Apex2 would have more sustain being a fixed bridge guitar. I'd check the setup.
mike570 is offline
post #3 of 7 (permalink) Old 03-15-2011, 11:43 PM Thread Starter
HoP
Actually after looking at the two... I realized their wiring is going to be completely different since the APEX2 is using a 3 way, and the 1527 is a 5 way. (both using dual buckers obviously) im wondering if I swap the 3 way out for a 5 way if the wiring would make a difference in PUP sound. unfortunately I dont know a whole lot about wiring, the wiring I have done has just been following diagrams.. if anyone with wiring exp could help out here that would be awesome!
HoP is offline
post #4 of 7 (permalink) Old 03-15-2011, 11:50 PM
Reviews: 11
different wood type and different guitar options (fixed bridge vs. trem). the 2 guitars will probably never sound the same. its all about the wood and really has nothing to do with your blade switch
D.M.RG7620 is offline
post #5 of 7 (permalink) Old 03-16-2011, 12:24 AM
switch only matters in position 2 and 4 on the 1527 . Its the wood and the bridge
dragsternj is offline
post #6 of 7 (permalink) Old 03-16-2011, 08:21 AM
I have heard that active EMG's sound basically the same no matter what kind of guitar you put them in. You can also try putting some brighter sounding pickups in the Apex to balance out the mahogany. Really though, with having different body woods, they'll never sound same.
There's got to be something with how the Apex is setup that's affecting your sustain. It should definitely have more than the 1527 in my opinion. Give it a little more neck relief, see how the sustain improves.
xXLinkageXx is offline
post #7 of 7 (permalink) Old 03-16-2011, 08:27 AM Thread Starter
HoP
Linkage, the reason I felt it was an electrical/wiring issue was because I can physically see my strings sustaining on the APEX2, but its like the pups are cutting short, sounds like they just dont have as much "drive" and "hotness" of my 1527. I never thought that body wood has THIS much effect on sound.
thanks for all the replys guys
HoP is offline
RG1527 & MacAlpine Sound ibanezman1527 All Other Guitars (including Prestige) 13 03-02-2011 02:17 PM
HSH issues - SOS! Voice Of Reason All Other Guitars (including Prestige) 5 11-19-2010 01:39 PM
Can wiring issues cause a pickup to sound microphonic? Rotti Pickups & wiring 4 04-28-2009 08:50 AM
Sound Clip: How do I get my JS-1000 to sound like this? DMTransmutation Ibanez JEM, UV, JS & Other Signature Models 7 03-08-2009 08:41 AM
Wanted: KoRn APEX2 (string through) body Mr.WizardNeck Classified Ads: Guitars and Gear 0 03-10-2008 02:11 AM
