RG1550 vs RG2570 as a project base? Any differences? - Jemsite
post #1 of 36 (permalink) Old 10-08-2012, 07:54 AM Thread Starter
As title really, I'm looking at a couple of these bodies as projects and wondered if there are any significant differences between them, i.e. type of wood, which bridge will fit, which neck will fit etc.
JayCartay is offline
post #2 of 36 (permalink) Old 10-08-2012, 04:10 PM
Re: RG1550 vs RG2570 as a project base? Any differences?
Same thing. necks different (inlay).
Expensive as a start for a project, though I guess you're more than an amateur.
Ibateur is offline
post #3 of 36 (permalink) Old 10-08-2012, 04:38 PM Thread Starter
No, not massively experienced with projects bit have built up an Epi Dot with new pots, pickups, wiring, bridge, tailpiece and tuners. I also paid to have a new nut fitted. I like to build stuff, and I'll never save up the cost of a Prestige so buying it bit by bit and building it to my own spec seems a good plan.
So are the necks the exact same shape/profile?
post #4 of 36 (permalink) Old 10-08-2012, 06:53 PM
Reviews: 120
The necks are the same shape/profile, etc, yes.
Just get the RG1550 if you are looking for a project base. It's cheaper, but has the same specs where it counts.
LonePhantom is offline
post #5 of 36 (permalink) Old 10-08-2012, 07:10 PM Thread Starter
If the only differences are electronics and the fretboard inlays, I might. But the bodies I've seen are basically the same price so there's no saving in buying the 1550 from that perspective. Do they both take the same bridge?
post #6 of 36 (permalink) Old 10-08-2012, 09:07 PM
Reviews: 120
Within the same year of manufacture, yes.
post #7 of 36 (permalink) Old 10-09-2012, 02:50 AM Thread Starter
Which bridges would I be looking for?
post #8 of 36 (permalink) Old 10-09-2012, 03:28 AM
Reviews: 120
Any year of the Prestige model guitars come with good bridges. Edge Pro, until a few years ago when it was replaced with the Edge Zero. Read up on them and decide what sounds best to you, and buy the body that holds that particular bridge.
post #9 of 36 (permalink) Old 10-09-2012, 12:26 PM Thread Starter
I've now just seen an Ibanez RG4EX1 body available and it's a beautiful colour.....
Would I lose out on anything over the Prestige bodies by using that? I'm going to fit my own choice of pickups etc. anyway. I noticed it takes an Edge III trem though. Don't know much about that.
Which necks do they take and are they made of the same wood as the Prestiges?
post #10 of 36 (permalink) Old 10-09-2012, 06:12 PM
Reviews: 120
Edge III is junk, but if you are happy to pull the Edge III anchors out and install Edge Pro ones (much better quality), the Edge Pro is a direct fit.
post #11 of 36 (permalink) Old 10-09-2012, 08:04 PM Thread Starter
Would that be a very difficult job and would the replacement fittings be easy to obtain? This body is LOVELY but there is also a silver RG2570 body available.... Hmm....
post #12 of 36 (permalink) Old 10-09-2012, 09:31 PM
Reviews: 120
Not difficult if you have a bench drill. Pull the old anchors out, fill the holes with dowel, redrill to fit the new anchor. Studs and anchors can be bought from your local Ibanez dealer, Ibanez Rules, e-Bay, etc.
post #13 of 36 (permalink) Old 10-09-2012, 10:48 PM
RGTFanatic's Avatar
Don't forget that the RG4 has ring mount pickups instead of the direct mounts in the prestige's. If you want to get rid of them you can fill the 8 screw holes, but they will be noticeable......the dog ear routes are asymmetric and quite ugly on these guitars as well. You should also note that the veneer on the RG4 is extremely thin (1.5mm) and will sand thru before you can remove the color, so a refinish is out. The RG4 also has the WizardII neck that, while I like it a lot, is VERY different from the Wizard prestige necks both in finish AND feel.
The big difference between the 1550 and the 2570 is that the 1550 is front route (requires a pickguard) and the 2570 is rear route. You also NEED to know what year each body is. Both models came with either the Edge-Pro or the Edge-Zero depending on the year they were made. AFAIK, the two trems are NOT interchangeable.
RGTFanatic is offline
post #14 of 36 (permalink) Old 10-10-2012, 08:58 AM Thread Starter
I don't really want to go to those lengths re: the bridge. I think I'll buy the RG2570 body and look into a refinish as I'd prefer a nicer colour scheme than the silver.
post #15 of 36 (permalink) Old 10-14-2012, 07:02 PM Thread Starter
I've found a nice RG2570 body in silver, so won't need to refinish
Next question, what's the part number of the bridge? I've seen a various number of different bridges listed as Prestige Edge Pro but they have a different BR- number.
prestige , project , rg1550 , rg2570
Difference between white base and solid base ibanez jem 77dy knobs? Verus Ibanez JEM, UV, JS & Other Signature Models 8 02-11-2010 09:38 AM
Base Pickup? theapprentice Pickups & wiring 4 02-20-2009 12:19 PM
WANTED: Chrome locking nut base ZOMB13 Classified Ads: Guitars and Gear 0 01-12-2008 07:25 PM
How to fix a single-coil (at the pickup base)? Stygian Gear, Equipment, Recording & Off Topic 0 05-24-2007 11:41 PM
what angle should the base plate of the edge pro II be? IBANEZRGONFIRE Tech: Setup, Repairs and Mods 0 06-06-2006 02:19 PM
