RG1570 vs. RG2550Z - Need advice. Ready to pull trigger! - Jemsite
post #1 of 8 (permalink) Old 02-02-2009, 10:16 AM Thread Starter
I'm about to pull the trigger on a Prestige, and I'm undecided.
I played the 2550Z - AWESOME guitar. Haven't played the RG1570, can't find one to try. I like the dot inlays better than that of the 2550Z.
Can someone enlighten me on the bridge difference on the RG1570?
Will it change the over pitch if If I drop-D tune on the E string? The Z bridge doesn't.
I can get the 2550Z for $799, since it's being discontinued, and the 1570 is actually a little more. I think the 2550's bridge makes it the better buy, but I'd like opinions.
Thanks!
ibanezgas is offline
post #2 of 8 (permalink) Old 02-02-2009, 10:50 AM
Re: RG1570 vs. RG2550Z - Need advice. Ready to pull trigger!
ive got a rg2550z.nice guitars,no probs with the trem stays in tune ok.wasnt keen on stock pups but ive changed them to evo's,cant stand stock ibanez pups.i havent played the guitar since i gave it to the guy who's replacing pups,but should sound great.
rob777vdy is offline
post #3 of 8 (permalink) Old 02-02-2009, 01:16 PM
The 2550's stock pickups are much better than the 1570s. The Dimarzio/IBZ will also have a greater resale value than the V7, V8, S1 in the 1570. So if you are planning on replacing the pickups, keep that in mind.
jallen is offline
post #4 of 8 (permalink) Old 02-02-2009, 01:30 PM Thread Starter
I'd probably go with SD JB/Jazz set-up in either.
post #5 of 8 (permalink) Old 02-02-2009, 02:18 PM
ah sorry forgot to add,ibanez/dimarzio are a lot better than ibanez v7 v8 ect.
post #6 of 8 (permalink) Old 02-03-2009, 04:59 PM
1570 has a nicer trem. I have a 1570 With a Edge Pro and an RGT320 with am Edge zero. While the EZ has some good points, the EP is a better constructed bridge and, in my opinion, easier to play-right hand wise.
S
scotteggshell is offline
post #7 of 8 (permalink) Old 02-25-2009, 07:26 AM
I'd say get the rg2550z it looks alot nicer IMO. i was planning on getting the 2550z in white but found a good deal on an rg1570 used. it's an awesome guitar. pretty sure which ever you buy you'd be happy.
eVo
ericxvo7 is offline
post #8 of 8 (permalink) Old 02-25-2009, 08:31 AM
j.p
in my opinion go for 2550.it has better p.u. and you'll sell it easier in the future(if you need to).
j.p is offline
rg1570 rg2550z
Just pulled the trigger on a mint '98 7VWH on the Bay luvuvibanez Ibanez JEM, UV, JS & Other Signature Models 4 02-08-2007 06:35 AM
Ibanez RG1570-Dimarzio pickups, need advice Hunter All Other Guitars (including Prestige) 9 02-03-2006 12:50 AM
BAM! Pulled the trigger on 1077XL MidusGT All Other Guitars (including Prestige) 9 11-13-2004 04:08 PM
Planning to buy an RG1570, need advice voyager All Other Guitars (including Prestige) 23 10-09-2004 04:05 PM
JS1000BP 2001 factory set up - Ready to play or needs ready YngVaiTriani Ibanez JEM, UV, JS & Other Signature Models 7 09-08-2001 05:14 PM
