RG20th Casing Problem? - Jemsite
post #1 of 21 (permalink) Old 09-09-2007, 12:32 PM Thread Starter
Hi Guys,
just wondering if you all have any problem fitting the rg550 into its case?
Because the body of my DY will not rest flatly inside the case. The guitar is slightly lifted upward from the neck joint area onwards as the neck support portion of the case seems to be too high, thus lifting up the guitar and causing a gap in between the neck joint and the base of the case.
The guitar is resting in a slanted position when inside the case.
Headstock(highest point) >>>>> Body(lowest point)
PinkSpId3r is offline
post #2 of 21 (permalink) Old 09-09-2007, 12:35 PM
Re: RG20th Casing Problem?
Originally Posted by PinkSpId3r View Post
Hi Guys,
RG550MXX and RXX models should have come with Prestige style cases instead of the non-form fitting ones Ibanez decided on. This is just someone being cheap IMO, never mind the "colour matching cases!!! OMG!!!".
bringer of torture is offline
post #3 of 21 (permalink) Old 09-09-2007, 02:46 PM
Dino's Avatar
Both of mine fit okay. Not great but okay.
Dino is offline
post #4 of 21 (permalink) Old 09-09-2007, 02:51 PM
Suspended
All of mine fit OK.
Minimum Bob is offline
post #5 of 21 (permalink) Old 09-09-2007, 03:04 PM
My pitiful one fits ok
markg5150 is offline
post #6 of 21 (permalink) Old 09-09-2007, 03:37 PM
Dee
Mine fits OK, but I agree with the above comment. It's hard to believe Ibanez decided to cheap out like this with the 20th cases.
Dee is offline
post #7 of 21 (permalink) Old 09-09-2007, 03:43 PM
Well.....get it out of the case and play the damned thing then
andy7jem is offline
post #8 of 21 (permalink) Old 09-09-2007, 03:45 PM
Dee
Mine's been out of it's case since I got it and it's played daily. How you getting on with yours, Andy?
Dee is offline
post #9 of 21 (permalink) Old 09-09-2007, 04:08 PM
Loving it
Do they fade a lot if left out??? Coz i keep my guitars on stands. I try to keep the curtains closed during the day to keep the sun off it
andy7jem is offline
post #10 of 21 (permalink) Old 09-09-2007, 04:12 PM
Originally Posted by andy7jem View Post
Loving it
Do you have sun in England?
FloridaNative is offline
post #11 of 21 (permalink) Old 09-09-2007, 04:12 PM
Suspended
Maybe try some of this stuff?
http://www.abodewindowfilms.co.uk/ac...ndow_film.html
post #12 of 21 (permalink) Old 09-09-2007, 04:14 PM
Suspended
He's trying to keep the glow of the DY off the Sun so it doesn't fade any more than it already has.
post #13 of 21 (permalink) Old 09-09-2007, 04:27 PM
Occasionally
andy7jem is offline
post #14 of 21 (permalink) Old 09-09-2007, 09:02 PM
Dee
Andy, I was informed earlier this year that these reissues have better paint, less likely to fade like the originals. On the other hand, I read somewhere that they used the exact original paint formula.
Go figure...
Dee is offline
post #15 of 21 (permalink) Old 09-10-2007, 07:17 AM
Reviews: 10
yeah mines similar, i dont like the idea of pressure been added to the neck joint so I stand my case up vertically against a wall.
Reason why I keep mine in the cases is because of dust, dust gets everwhere and it's a git when it works its way into the bridge and pick ups.
The worst case I bought was an Ibanez one that says its for RG's and all the guitar weight made it go on the neck joint. I had to rip out the inside bit so it lays flat, but weight is on the head, and so still putting pressure on the neck joint, so i pad the neck joint so the weight goes on the body. I use that case for my 350.
You'd think it'd be pretty simple to make a case!
The Jem case is the best, made to fit perfect. But the 20th case is ok, least it's better than the case my 350 is in.
richard1973 is offline
ibanez hardshell , neck joint
Problem with 2003 7Vwh JEM, Possibly New Edge Pro Trem Fault leonard deroma Ibanez JEM, UV, JS & Other Signature Models 89 06-18-2007 10:57 AM
Guitar buzz problem... seongkeat Tech: Setup, Repairs and Mods 8 05-17-2007 07:38 AM
Saddle problem on Edge Pro ThomasBJ Tech: Setup, Repairs and Mods 11 04-12-2005 02:05 PM
JCM2000 DSL100 volume swell problem Joshka Gear, Equipment, Recording & Off Topic 40 04-14-2004 05:49 AM
I've finally got the RG2820...however, one problem..advice? triaxis All Other Guitars (including Prestige) 11 11-16-2003 09:06 PM
