rg2127x intonation and bridge problems - Jemsite
post #1 of 4 (permalink) Old 09-30-2002, 03:09 AM Thread Starter
So i got my new axe last friday, but I have a huge problem with it. I first tuned it up with the factory strings still on it, then I thought, let's get my favourite strings straight away. Ernie Ball slinky's: .010 .013 .017 .026 .036 .046 .056
So i let the guitar get used to the strings for about half a day, (the bridge was WAY up!) I loosened the strings, to adapt the springs for the bridge. Now, what it basically comes down to, is that I turned the screws for the bridge (screws for the springs) as far in the body as possible, but STILL i have a way too high action. I know I should pay attention to the little stripe on the LO PRO EDGE to set it up right... Do you think it's the strings? Have you had experience with this?
Furthermore, when I try to intonate, I have the same problem. A boundry...
I need to move the saddles away from the neck, to achieve the right intonation. The problem is, i can't move the saddles any further away (fine tuners in the way), still the intonation is not correct.
Have you people experienced this? IS it my strings? I do not want to change gauges for this. But that shouldn't be necessary right? These axes should be ok with up to .013 gauge strings right?
Anyway, any help on this is VERY welcome.
P.S. It might be important to add, that the saddle problem, is the same as what I have on my ESP (i can get the intonation JUUUUUST right on this one) on which I also use Ernie Ball .010 through .046
btw, I'm talking about normal tuning, so no dropped D or whatever...
Raffel is offline
post #2 of 4 (permalink) Old 09-30-2002, 03:15 AM
You need at least 4 springs with that guage.
It's not the fine tuner but the string lock screw that keeps you from intonating the low E, and sometimes the A. I know a guy that had a couple reshaped shorter so it would intonate.
Rich is offline
post #3 of 4 (permalink) Old 09-30-2002, 03:48 AM Thread Starter
yes you're right, it IS the string locks, my mistake. But will the 4 springs solve the intonation problem?
Mods, sorry for double posting. You can close this topic here, as I posted it in repairds and mods already...
Raffel is offline
post #4 of 4 (permalink) Old 09-30-2002, 06:43 AM
My 2027 is setup with .10's as yours, and it needs 4 springs. Get a new spring, put it in and the bridge should go into the right position 9look in the tech section) which should sort everything out nicely
James
7 Dying Trees is offline
Closed Thread
ernie ball , gauge strings , pro edge , string lock
Intonation problems hp29 Tech: Setup, Repairs and Mods 4 03-05-2012 02:05 AM
Setup Problems (Intonation etc.) IrishIbanezFan Tech: Setup, Repairs and Mods 13 11-30-2010 10:39 AM
Intonation Problems With RG1570. PLEASE HELP! shogun Tech: Setup, Repairs and Mods 20 03-29-2007 08:35 AM
Intonation problems on my 7vwh. Willin Tech: Setup, Repairs and Mods 1 10-25-2003 05:35 PM
Spontanious intonation problems! Thegeneral Tech: Setup, Repairs and Mods 7 05-29-2002 12:01 AM
