RG2610E Body.......Neck & Trem Options - Jemsite
post #1 of 3 (permalink) Old 10-10-2012, 07:25 PM Thread Starter
I have an extra RG2610 Body lying around that came originally with an Edge Pro. It still has the stud bushings but nothing else. Personally, I like the bubinga striped Wizard necks from the late 90's/early 00's better than the Prestige neck that came on the 2610. I take it that a bubinga striped Wizard neck will bolt right onto the 2610 body in perfect position without modification ???
Also, given that the body came originally with and Edge Pro and has the Edge Pro stud bushings still intact, am I stuck with having to go with an Edge Pro or will a regular Edge and Edge studs screw into the Edge Pro stud bushings ?
OliverKlohzoff is offline
post #2 of 3 (permalink) Old 10-10-2012, 10:06 PM
Reviews: 120
Re: RG2610E Body.......Neck & Trem Options
The Prestige necks are slightly wider than the earlier MIJ necks. You'll have slight gaps either side of the pocket.
To get an edge or Lo Pro Edge to fit you'll have to make the tremolo cavity a bit wider too.
LonePhantom is online
post #3 of 3 (permalink) Old 10-10-2012, 10:49 PM Thread Starter
OK thanks. I guess I need to find an RG1570 with a beat body but good neck and trem.
rg2610 edge pro
Ibanez solid body with a THICK neck...any options? S540Sabre All Other Guitars (including Prestige) 21 02-28-2012 07:39 PM
Jem Body Trem options jempc Tech: Setup, Repairs and Mods 6 12-01-2010 05:47 PM
FS Ibanez RG1550BK (loaded body) plus neck (two options to choose) supergirl20_06 Classified Ads: Guitars and Gear 1 02-10-2010 12:50 PM
FS Ibanez JEM555WH (loaded body) plus neck (two options to choose) supergirl20_06 Classified Ads: Guitars and Gear 3 02-10-2010 12:49 PM
FS Ibanez RG1550FM (loaded body) plus neck (two options to choose) supergirl20_06 Classified Ads: Guitars and Gear 0 01-18-2010 09:20 AM
