RG3120 high e string problem! - Jemsite
post #1 of 23 (permalink) Old 01-27-2015, 03:10 PM Thread Starter
The high e string on my RG3120 is much closer to edge of the frets than the low e string causing the string slip off the fretboard with even the smallest amount of vibrato or slight mis-fret.
This has driven me to the point where I've considered selling the guitar because it is so frustrating, but before I do, does ANYONE have a suggestion on how this can be fixed? The trem and nut are set up correctly as is the true rod. The neck also appears very straight.
I would greatly appreciate any suggestions as this is starting to become a deal breaker with this guitar even though I love every other aspect of playing it. Thank you!
chilln2music is offline
post #2 of 23 (permalink) Old 01-27-2015, 04:40 PM
Re: RG3120 high e string problem!
There is normally some room for adjustment if you loosen the neck screws. Loosen the strings first.
http://www.ibanezrules.com/tech/grunge/grunge_6.htm
just4kinks is offline
post #3 of 23 (permalink) Old 01-28-2015, 02:25 AM
yup... it's a very thin neck.. happens to me too. I thought it was due to my specific guitar but then it seems to be a more generic thing.
I kinda adjusted to it though.. but I don't apply lots of vibrato on the high E
mindwalker is offline
post #4 of 23 (permalink) Old 01-28-2015, 04:00 AM
My uv70p had the same problem. The cause was that due to the design of the AANJ there is less resistance on the treble side than the bass side, so the neck has the tendency to "fall" down a bit. The solution as just4kinks said is to loosen the strings and then unscrew the neck bolts, re-align and then screw tight (but not way too tight). I measured my clearance between neck heel pocket on the treble side and the neck heel and it is constantly about 0.1mm, which is a sign of a permanent fix, no matter the wild dives, pull ups, etc...
panix is offline
post #5 of 23 (permalink) Old 01-28-2015, 04:22 AM
I got one guitar exactly like this, neck pocket is really tight, no room for adjustment.
found out that the source of the problem was the tremolo pivot is 1mm away to the right from where it should be.
Well, I'd guess I've got a lemon.
psychoshredder is offline
post #6 of 23 (permalink) Old 01-28-2015, 04:52 AM
Just by very lightly sanding the neck pocket to create room for the bass side of the heel, might prove enough to fix the problem without plugging re-drilling for the trem inserts. You might want to collect the dust from the sanding and glue it to the treble side of the neck, or keep it safely in its case if you feel paranoid enough
panix is offline
post #7 of 23 (permalink) Old 01-28-2015, 07:49 AM
there is a less headache and less pain way to do this man....
sell the guitar... LOL
post #8 of 23 (permalink) Old 01-28-2015, 08:46 AM
^^^ Kids these days, looking for the easy way out!
panix is offline
post #9 of 23 (permalink) Old 01-28-2015, 09:57 AM
it happened that my guitar with that kind of problem is my less significant guitar.
I don't plan to keep it forever, so this minor defect just adding another reason for its earlier departure..
post #10 of 23 (permalink) Old 02-07-2015, 06:27 PM
Happens to me from time to time on my RGT3020. i feel like the neck is narrower than on other guitars.
Yngvai-Satrucci is offline
post #11 of 23 (permalink) Old 02-12-2015, 10:35 PM Thread Starter
Thanks for the replies.
I did try realigning the neck in the pocket but there is no play in the pocket to move the neck. Has anyone successfully tried sanding the pocket on the treble side to "cheat" the neck towards the treble side?
post #12 of 23 (permalink) Old 02-12-2015, 10:57 PM
I wouldn't recommend an amateur sanding the pocket, especially mahogany for the first time. Not that you can't do it.
I'd pull the trem out [with the strings on], take the strings off, and take it to Home Depot or Lowes and find a good pair of "cutting pliers". Grip the locator [curved] knife edge flush along the inside edge next to the saddle, and bite down hard before you pry the knife outward. Make sure the pliers are not slipping before prying, you only get one good shot at it virgin, and if you slide across the knife and it doesn't move, it will gouge and be very difficult to get good enough grip on it again. There is a detent in the knife that keeps it tight and it requires force to break the tension. You only need 1/2mm, but it's easy to tap it in if it's out too far when you install again.
That's the easiest way to fix that guitar.
Rich is offline
post #13 of 23 (permalink) Old 02-13-2015, 10:58 AM
RGTFanatic's Avatar
Awesome idea man, I've never even thought of trying to move an insert for alignment issues.......brilliant!
Do you use Dykes or or something like a fence nip?
RGTFanatic is offline
post #14 of 23 (permalink) Old 02-13-2015, 02:42 PM
cutting pliers
Rich is offline
post #15 of 23 (permalink) Old 02-13-2015, 02:50 PM
nice trick indeed.
panix is offline
rg 3120 , rg prestige , rg3120
Cort EVL-K4 Setup High e string buzz problem,,,, need help !!! klaus12 All Other Guitars (including Prestige) 1 09-30-2012 04:16 PM
fret buzz on high e-string - truss rod adjustment problem? Santuzzo Tech: Setup, Repairs and Mods 7 08-10-2011 08:07 PM
Sustain problem with top / high E string Max Dread Tech: Setup, Repairs and Mods 12 12-22-2010 04:07 AM
high E string problem mike2558 Tech: Setup, Repairs and Mods 1 05-02-2007 10:51 PM
High E string action problem John Tech: Setup, Repairs and Mods 22 06-08-2005 01:22 PM
